Activity Forums Maxon Cinema 4D Xfrog help
  • Xfrog help
    Posted by Steve on April 14, 2006 at 3:33 pm
    I just acquired the Xfrog plugin with the Xfrog plants: Flowers cd. So I was really excited because the previews on the cd look awsome, so I load up a rose from a folder on the cd, then, I tried merging another flower from another folder on the cd (exemple: the woulde be the folder called FL07:Rose, than I would load something from a different folder FL04) and the rose would be fine but the new flower would be textureless, so I was like ok, lemme just reload the textures, but that didn’t change anything. Now if you think that’s weird, once I deleted the newly merged item, I imported a flower from the same rose folder (there’s more than 1 model per folder…different types of roses…. maybe I should use the word model instead of rose, anyways) and the new one would work. So more than 1 item from the same folder = fine, models from different folders = no textures on the new imported objects. Can anyone help me:)
    Steve replied 20 years, 5 months ago 1 Member · 1 Reply
  • Steve
    April 14, 2006 at 3:58 pm
    Ok well never mind I fixed the problem, since my xfrog wasnt importing the texutres well, I set my texture search path to my g drive (the cd)and its fine, but is there any other way, cuz now its running slower.
