Activity › Forums › AJA Video Systems › Xena Card and Prospect HD
Posted by Chad Briggs on April 17, 2006 at 4:53 pmIs there anybody on the forum using the Xena PciExpress card and the Cineform codec? I’d love to hear if anyone has used it for extensive greenscreen/bluescreen work? The codec is 10bit 4:2:2 correct?
thanks for any info
ChadMatt Grindlay replied 19 years, 11 months ago 3 Members · 3 Replies -
Tim Kolb
May 1, 2006 at 1:20 pmI know no one has answered you here…and it’s not as if none of us use the CineForm system…though I have not personally keyed with it yet (which is why I did not respond to your post immediately), I know it should work very well because as you note, it’s 4:2:2, 10 bit…and full raster (unlike DVC ProHD or HDcam natively).
TimK,
Kolb Productions,
Creative Cow Host,
Author/Trainer
http://www.focalpress.com
http://www.classondemand.net -
Chad Briggs
May 1, 2006 at 4:42 pmTim-
Thanks for your thoughts. The only other strange thing i’ve noticed is that you acutally have to pay for every machine you want the codec on? Doesn’t that make it a little counterproductive in a worfklow? For example, matrox gives away it’s software codecs, so you can comp/animate on other machines, then take it to the matrox for output. Or am i missing something and making it more complicated thatn it needs to be.
thanks
Chad -
Matt Grindlay
September 25, 2006 at 9:44 amHi Chad,
I’m in the process of setting up Aja & Cineform, so haven’t tested too much yet. I discussed this exact question with Cineform tech support. They said to install the trial and then uninstall, when uninstalling it will prompt you to leave the codec on the computer. This I understand won’t expire and will allow playback of cineform on that computer (I don’t know if it will allow encoding I haven’t tested it)Hope this is of some use.
cheers,
Matt
