Activity Forums AJA Video Systems XENA batch capture timecode arror
  • XENA batch capture timecode arror
    Posted by Chris on May 26, 2007 at 8:20 am
    I’m trying to batch capture (Xena – Premiere Pro / A500 DigiBeta) from an Avid Adrenaline edl and the timecodes are out by 2 seconds or so. All clips are coming in 2 seconds early. Now I know I can offset the timcode, but what’s the reason this is happening anyway?
    Also if I go into capture setting the Aspect Ratio (Primary Format) is locked on 1920×1080 even though I set the the project up in SD. I can’t change this for some reason. Again, anyone experiecing anything similar?
    thanks
    e
    Chris replied 19 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
