Activity Forums AJA Video Systems XENA 2K PREMIERE CS2
  • XENA 2K PREMIERE CS2
    Posted by Chris on August 30, 2007 at 12:04 pm
    I’ve just installed the ver 3.00 drivers and timecode / deck control has died. Unistalled and reinstalled 2.6 drivers and they don’t work anymore either.
    Sony A500 deck through RS422 – using Insert Edit – deck gets to TC in point and doesn’t record.
    Print to Video – just seems to create an arbitrary TC point to start recording.
    Also – going from capture to export to Tape – Premiere STILL crashes (which I thought was solved in this version)
    I’m stuck can anyone help?
    e
    Tim Kolb replied 18 years, 12 months ago 2 Members · 2 Replies
  • Chris
    August 30, 2007 at 1:04 pm
    More detail:
    When using ‘Export to Tape’ in Insert Edit or Print to Video mode, the ‘Duration’ figure to the right of the panel always displays 1 frame (00:00:00:01). Regardless of length of timeline.
    Hence nothing going to tape.
    This is really causing me problems.
    e
  • Tim Kolb
    September 5, 2007 at 11:15 am
    What exactly was the procedure you used for first the upgrade, then the revert back to the old drivers…?
    TimK,
    Director,
    Kolb Productions,
    Creative Cow Host,
    Author/Trainer
    http://www.focalpress.com
    http://www.classondemand.net
