Activity Forums Adobe Premiere Pro XDCAM.MOV only bringing in 1 channel of audio
  • XDCAM.MOV only bringing in 1 channel of audio
    Posted by Trent Diggity on June 4, 2012 at 6:56 pm
    I’ve got a .mov quicktime that is the xdcam codec. It imports fine into final cut with 6 layers of audio. When I try it in premiere, only one channel comes it and will not play.
    The file does not open in the new quicktime but opens fine in quicktime 7.
    I know i could throw it in compressor and spit out a pro-res file BUT the clip is two hours long, and this format is coming from a client so I know that I will see more of this problem in the near future.
    I thought it might be codec related but since premiere comes with xdcam preloaded, not sure if i really need to try to install them – I’ve looked on their site and can’t find an installed to the xdcam codec. I did try installing the browser, hoping the codecs would be with it, but no love there.
    also to clarify, FCP is on a different machine from Premiere.
    I’m running the most updated version of cs5.5
    does anyone have any suggestions?
    Jim replied 14 years, 3 months ago 4 Members · 6 Replies
  • Wendell Davis
    June 4, 2012 at 7:15 pm
    Make sure in your preferences that you have it set up for the number of audio files you have and what tracks you want them to go to. I use XDCam all the time and had to set up a specific audio import setting preference so that the tracks are always split to mono for individual editing.
    Hope that helps.
  • Trent Diggity
    June 4, 2012 at 7:48 pm
    Hey Wendell,
    Can you be a bit more specific to where that preference is?
    I check preferences through Premiere Pro>preferences and I don’t see anything about audio importing on any of the tabs. I did however get it to admit to me that there were 6 channels of audio by going to file>get properties for…>file and it tells me that there are in fact 6 channels.
  • Wendell Davis
    June 4, 2012 at 8:59 pm
    Mac or Windows… little different. Mac under Premiere Pro > Preferences, Windows under Project down the bottom > Preferences.
    For a single file you can modify it. Right click on the file and up comes a dialog box. chose 6th down Modify. Then you can set up the audio anyway you want. It is also under Clip.
    I actually made my own preferences for the way I work so all files come in split track mono. With 6 audio layers you will have to do some work.
    There are a bunch – 36+ videos on the new CS6 PrP in the tutorials. I just changed over and have been watching them in my hotel each night. I believe the guys name is Devis. Real nice job. I’ve watched some of them a number of times. There is a good one specifically on this subject – couldn’t my finger on it at the moment.
  • Trent Diggity
    June 4, 2012 at 9:50 pm
    Sadly that did not work. It only sees 1 track of audio when doing it that way. I’ve got adobe on the phone now about it. So far no luck either. 🙁
  • Dave Fleming
    June 4, 2012 at 10:29 pm
    Trent,
    Sorry, no answers, but see my thread here:
    https://forums.creativecow.net/thread/3/923696#926141
    There is something VERY strange about how PPro imports audio (in my case, 4 mono channels coming from my XDCAM EX camera. Basically, in any environment except using Sony XDCAM Browser for import, you’re screwed. If you attempt any copy/paste functions of the BPAV folder (in may case), you can kiss all of your audio goodbye except for one channel. Nobody is saying if this is a PPro or a Sony issue.
    Dave
  • Jim
    June 5, 2012 at 3:55 pm
    I’ve recently upgraded/transfered to CS6 and since I also shoot w/ EX1R I wanted to check if I was encountering the same audio issues — Yes and No. If I bring in the file from the media browser to the time-line I get one audio track. If I bring the file into the Project folder and (rt click)modify audio to 2 tracks (mono) I get both audio tracks. Let me know if that works for you, or I was just lucky:-)
    Cheers,
