Activity Forums Sony Cameras XDCAM2FCP2Flash6 creates fuzzy results
  • XDCAM2FCP2Flash6 creates fuzzy results
    Posted by William Mccauley on December 4, 2008 at 3:47 am
    Not sure where to really put this one so I thought I begin at the front of the workflow.
    Problem is slightly fuzzy results in Sorenson Squeeze codec for Flash 6 player.
    We have used with EX-1 and 3, PDW330 &350 cameras at 1080P 35HQ- edited in FCP and cropped to 4×3, Exported to master Quicktime file using the xdcam settings. The file is then processed in Sorenson v4.8 to create a 400×300 Flash 6 compatible swf file. The image results are a touch soft compared to using the same workflow with DV cam sources or XDCAM at 720P. On the surface it seems like I’m shooting a gnat with a cannon but the results are puzzling. Generally when you shrink bits images can get sharper not softer.
    Any Ideas…
    Rafael Amador replied 17 years, 9 months ago 2 Members · 1 Reply
  • Rafael Amador
    December 4, 2008 at 12:18 pm
    [William McCauley] “Exported to master Quicktime file using the xdcam settings. “
    Hi William,
    The XDCAM codecs are for acquisition. You better export in any other codec, like ProRes.
    Cheers,
    rafael
    http://www.nagavideo.com
