Activity › Forums › Avid Media Composer › XDCam video playback stutters
  • XDCam video playback stutters
    Posted by Marc Murray on November 19, 2009 at 6:15 pm
    Editing on Macbook Pro 2.2 Core 2 Duo, 4GBs ram on Avid MC 3.5. Using several external drives, but for this question, it’s a Lacie Rugged 500GB Firewire external (might be 5400 RPM…not sure).
    My XDCam footage (35MPs) stutters horribly. I’ve tried USB 2.0, Firewire and my internal and it continues.
    I’m updated with Avid, but can’t discern what the issue is….codec? drive? firewire?
    argh!
    Kevin King replied 16 years, 4 months ago 4 Members · 6 Replies
  • Michael Phillips
    November 22, 2009 at 3:26 pm
    Most likely the drive speed and connection to the system. Are you using FireWire 400 or 800? Is it really a 5400RPM disk?
    Michael
    Michael Phillips
  • Marc Murray
    November 23, 2009 at 12:58 am
    thanks for the reply. I just installed a new 500GB internal Seagate 7200RPM drive, transfered the media (from a FW 800 drive) and it still stutters.
    Video card? I have a GeForce 8600M GT on my MBP. I have 4gb ram, so it can’t be that.
    I’m wondering if it’s the source media…hmmmm
  • Michael Phillips
    November 25, 2009 at 1:39 pm
    Make sure your raster is set to thin or full depending on the data rate of your acquisition to see if that adds any performance. Also try transcoding one of the source clips into a DNxHD format and see if that drops any frames.
    Michael
    Michael Phillips
  • Kevin King
    May 13, 2010 at 3:02 pm
    I’m having the same exact issue. XDCAM footage (1080p/23.98) stutters noticeably when it plays back on MC4.0.5. The stutters is equally bad whether the media plays back via AMA or if its been transcoded to Avid media files (MXF) via one of the DNxHD codecs. The media lives on an internal sata drive on a MacPro. And I’m certain the problem isn’t with the original footage because when I play back the same footage in FCP there is no stutter.
  • Matt Mullen
    May 13, 2010 at 3:30 pm
    Are you seeing any colored bars on the timecode track in the timeline
  • Kevin King
    May 13, 2010 at 4:53 pm
    no, there are no colored bars in the timecode track of the timeline.
