Activity Forums Sony Cameras XDCAM Transfer tool 2.12
  • XDCAM Transfer tool 2.12
    Posted by Bobby Jones on April 14, 2010 at 4:36 pm
    So I donwloaded 2.12 of the Sony Transfer Tool today on my Snow Leopard MacBook Pro. Everything works fine but I was under the impression that part of the reason for the update was to enable write back to a pro disk through the PDW-U1. That is not the case. I still have only “read access” and no write back. Anyone else in the same boat. My issue is I need to deliver my final project via XDCAM disk to its play back source.
    Daniel Wright replied 16 years, 4 months ago 2 Members · 1 Reply
  • Daniel Wright
    April 14, 2010 at 6:16 pm
    You need to install the XDCAM Drive Software. You can get it from here:
    https://support.sonybiz.ca/esupport/eSupportHome.asp
    Make sure you get version 2.3 if you are using Snow Leopard.
    Once you have installed this, the file structure of your discs mounted from the PDW-U1 will look very different when opened in Finder and they will be writable.
    HTH
