Activity Forums Sony Cameras XDCAM Transfer Problem
  • XDCAM Transfer Problem
    Posted by Olaf Steel on May 25, 2010 at 7:08 pm
    I have shot a short film on a Sony EX1 camera using SxS cards. When the cards were full, I put then in my MacBook Pro and copied the BPAV files to an external hard drive, a process I have done many times without problems in the past.
    Now however, I tried to view the latest files in XDCAM Transfer and when I try to add the files, I get the following error message: Error – Failed to import movie at (path).
    I can click on two buttons in the error window: Cancel all tasks and continue. If I click continue, all the thumbnails come up, but many of them are grayed out.
    I can play back all the files in VLC just fine, but they fail to work in XDCAM Transfer. I have just upgraded it and it still does not work.
    I have also tried to use XDCAM Transfer on another Mac and using Clip Browser on a PC. Still nothing.
    Any help with this would be greatly appreciated.
    Olaf
    Jeffrey Anderson replied 16 years ago 3 Members · 2 Replies
  • Christopher Kinsman
    June 5, 2010 at 4:33 am
    From our experience, you need to xfer the entire folders, not just the bpav files. Not aware of any fix for this – but haven’t done a lot of searching for this either.
    Best of Luck!
    Kind Regards,
    Chris
  • Jeffrey Anderson
    September 11, 2010 at 4:01 am
    Olaf,
    I had this same problem when I upgraded to Snow Leopard from Leopard, and there is a fix for this bug (although I would have to do some searching for the program to use to fix it; it’s from a Canadian website, I think). If you upgraded from Snow Leopard, this is probably the cause, and some searching will track down that file. I”m sorry I don’t know where it is, I think it was passed to me from a friend who helped me with the same problem. I am looking for it for someone else right now, if I find it, I’ll send the link.
    Respectfully,
    Jeff Anderson
