Activity › Forums › Sony Cameras › XDCAM transfer error
Posted by Adam1982 on April 5, 2007 at 3:03 pmJust bought the F350 camera and hurried back to the edit suite after the first shoot. I have FCP 5.1.4 and xdcam transfer ver1.1 but the camera won’t import via the firewire. I can view the proxies but when trying to import it starts then comes up with an error regarding smpte. Curious thing is i’ve tranferred some hd footage already when i demo’d the camera. anyone help, please
Mark Maness replied 19 years, 5 months ago 6 Members · 10 Replies -
Andy Mees
April 10, 2007 at 8:00 amplease post the exact error message and the exact steps taken to produce it.
also, what format are you shooting: HQ, SP, LP, or DV ?remember we can’t see what you’re seeing
Gareth Sylvester-bradley
April 11, 2007 at 7:36 amIf the error was like “invalid SMPTE key – 00.00.00…”, we saw this a lot with the first batch of Intel-based Macs. There was a firmware update for these Macs that fixed the problem from Apple. So, have you tried running Software Update and accepting any firmware updates?
Ic Media
April 13, 2007 at 1:34 amI just started getting this error yesterday. I have owned an F350 and F70 since September and it has always worked flawlessly. Using FCP 5.1.4 and XDCam Transfer 1.1.0. I was loading DVCam formatted footage and it wouldn’t import but I could watch the proxy file. I tried re-installing XDCam Transfer and that worked for a few clip imports and then it started again. Tried trashing the preferences file and that worked for 1 import and then I got the error again. I just kept re-trying importing each clip over and over and they eventually imported. I haven’t been able to find any info on this. Very strange…
Ic Media
April 13, 2007 at 12:54 pmUpdate on this: The footage that I imported has 1 frame of colored digital blocking about every 1 second or so. I know it was recorded clean because it plays out of the deck fine so there is some issue going on with the transfer software.
April 18, 2007 at 2:36 pmHi,
Since you say it has been working flawlessly since September, it sounds like something you installed recently has broken things.
Have you used Software Update since your system was last working correctly? (Updated to OS X 10.4.9 for instance?)
Or installed any other software?
Or upgraded the firmware of your F350 or F70?
It would be really helpful to identify what causes this.
Ic Media
April 19, 2007 at 12:06 amI have a hunch it is the 10.4.9 OS update. I can’t verify for sure because I’m not sure the exact day I did the update. When I get a chance, I will do a clean OS install (hopefully this weekend) and get back to 10.4.8. and see if that is the culprit. I haven’t done any other updates. By the way, this is on a G5 dual 2.5GHz and not an Intel Mac – not sure if this matters but it might.
Andy Mees
April 20, 2007 at 11:29 amfwiw there is no implicit conflict with 10.4.9 and xdcam transfer
even so.. it does seem as if you have a conflict somewhere. try a reinstall or better yet a clean install perhaps
Ic Media
April 22, 2007 at 1:26 amAll-righty then…
I did a clean install of the OS (had to go back to 10.4.0 and go up from there) and left it at 10.4.8 and then I re-installed the XDCam transfer software version 1.1 and now it works like a champ. No transfer errors. Trying to re-trace my steps, I think that I did the 10.4.9 update and then never used the transfer software until I had the problem.I guess it is possible that there could be a problem with OS 10.4.9 and XDCam transfer software version 1.1 on PPC Macs. I don’t have a lot of software installed on that machine so I don’t know what other factors may be involved. I know I have not done any other installs of anything recently. Anyone else out there encountered this?
Mark Maness
April 24, 2007 at 7:35 pmNext time, you might ought to consider downloading a copy of Carbon Copy Cloner. Just do a search on Google or Yahoo and you’ll find it. Then you can clone your boot drive before you do an update. This can get you out of many messes.
BTW, I have all of the latest versions with absolutely no problems with any XDCAM material in FCP 5.1.4 and MacOS 10.4.9.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
