Activity › Forums › Apple Final Cut Pro Legacy › XDCAM Transfer and Log Plugin ? Codec same as TRansfer 2.8
Ray Nygren replied 17 years ago 6 Members · 13 Replies
David Kaplowitz
September 15, 2009 at 3:11 pmi have a situation where installing the XDcam Transfer software (latest 2.0.10) has worked fine with either Log and Transfer OR the XDcam app itself – BUT on some machines (all MacBook Pros I believe), it will only recognize the SxS card using the XDcam Transfer app, NOT Log and Transfer.
I prefer to use Log and Transfer within FCP (able to send clips to a logging bin, more esily rename before ingesting, etc) so I’d like to crack this – any ideas what might not be right on those few machines? All are running 10.5.6 – 10.5.8
thanks in advance
Cosmin Osorhean
September 15, 2009 at 5:27 pmwhat do you mean by cracking? you mean, how do you solve this?
if you’re running SL you should know that Sony didn’t release the codecs for XDCAM yet. -
Ray Nygren
September 17, 2009 at 8:48 amIt looks like the Nattress plugins also work for FCS3. The now have more color plugins. Would the plugin you reccommended be in the big box or color.
The reason for in place prores 422 conversion is the size ratio of mp4 to pro res 422 is at least 1:3 and when shooting a 10 to 1 ratio of shoot to final edit this is significant
I have a documentary thats 500GB mp4 and in pro res 422 its 2 TB
