Activity › Forums › Sony Cameras › XDCAM Transfer
  • Claudio Manny
    October 28, 2008 at 7:25 pm
    Jeez, i’ve made a real mess….well hopefully someone is learning from all this…
    ive deleted the calibrated software but i’m still seeing the half image. What is the best way to rectify this?
    thanks
  • Don Greening
    October 28, 2008 at 7:26 pm
    [Craig Seeman] “It also says do NOT install their EX codec if you have FCP. That’s meant for playing back EX .MOV files on systems that do not have FCP.”
    ……and there you have it. Thanks, Craig for doing a bit more research than I was willing to do at the moment. I had a feeling Calibrated Q might’ve been an issue from helping a previous poster.
    The moral of this story is to read the fine print before installing any third party software.
    “Parts left out cost nothing and cause very few service problems.” – quote from a past president of GM and still true to this day.
    – Don
  • Craig Seeman
    October 28, 2008 at 7:49 pm
    Did they include an Uninstaller?
    You might need to contact them. I don’t doubt this has happened before (although it’s a very new product). There may be a hidden or buried file you’ll need to remove. It may be that you’ll need to do a complete uninstall and reinstall of the Pro Apps (Ugh!) or even an Archive/Install (and hope the buried file doesn’t get transferred) followed by a reinstall of the Pro Apps. That’s all speculation unless someone here who has had this happen, can answer.
    I suspect your best bet would be to email their support pronto because I’d suspect they’d at least give you something closer to definitive.
  • Michael Slowe
    October 29, 2008 at 10:38 am
    Although not involved with this thread (thank goodness!) I just can’t resist expressing my admiration of the way you chaps have analysed this problem. It’s great to know that such expertise is available to Cow devotees at the click of a mouse.
    Michael Slowe
  • Andy Mees
    October 29, 2008 at 4:04 pm
    >I just recently download a quicktime plug-in from the apple site called Calibrated{Q} MXF Import 1.2 to support some of the formats.
    Claudio ,
    To be clear we’re not chasing the wrong demon here, the Calibrated{Q} MXF Import 1.2 component is absolutely fine for use with FCP and allows the raw camera MXFs to be used without any need for rewrapping … its the separate XD, IMX and DVCPro Decode components that are not allowed for use with FCP (as they will directly conflict with Apple’s own codec bundles).
    So it sounds like you might have downloaded and installed more than just the MXF Import component …is that possible? If so, then its those additional components you need to delete/uninstall rather than the main MXF Import component. Delete those additional components and you should be fine (and you can even reinstall the main MXF Import component if you deleted that already). If you don’t delete those Decode components then reinstalling FCP won’t help you as those conflicting components will still be in the quicktime folder.
    Take a look in the /Library/Quicktime folder and delete:
    CalibratedIMXCodec.component
    CalibratedXDCodec.component
    CalibratedDVCProHDCodec.component
    And in the /Applications folder delete the whole Calibrated folder
    Now you can safely reinstall the MXF Import component from the demo installer. You should be fine after that.
    Cheers
    Andy
  • Don Greening
    October 29, 2008 at 6:29 pm
    Wow. Nice one, Andy. I’m going to have to check out this Calibrated Q thing for myself, as it may crop up again with someone else, and probably sooner rather than later.
    – Don
Page 2 of 2
