Activity › Forums › Sony Cameras › XDCAM Transfer 2.0 is out
Mark Maness
November 13, 2007 at 2:36 pmYes…
You’re right. Quicktime does offer timecode support now. BUT, I think that most users are looking for a heads up display just like the decks with character output.
I think that would be a great feature to have in the software, along with the ability to output proxy files with this info embedded on the video track, not just in it but on it. This is what I think that Proper Modulation was speaking of.
_______________________________
Wayne Carey
Schazam Productions
http://www.schazamproductions.com
https://blogs.creativecow.net/waynecarey -
Roger Price
December 18, 2007 at 9:39 pmI have the same problem on my Mac bok pro with leopard installed, can’t seem to rename disks, they dont write back to master disk. still will pull over footage though.
Mark Maness
December 19, 2007 at 2:39 pmWell…. I see it this way.
2.0 didn’t work very well at all. If you check Sony’s website, you’ll see that the full released version is 2.1. And this very issue that people are seeing has been fixed, at least from what I have witnessed on our systems.
Wayne Carey
Schazam Productions
Roger Price
December 19, 2007 at 8:55 pmI am running 2.1.0 version at the moment, thats not doing it either.
I will try a fresh start and see if it makes a difference.
Anyone also having this problem still under 2.1.0thanks
Roger
Kenny Park
February 26, 2008 at 1:35 pmI have the same issue. Attempts to rename the disc result in an “Invalid Source Name” message. I’m then told the name has to be smaller than 32 bytes, no matter what I try to rename it.
Also, the disc does not appear in the Finder, so I can’t rename it there as the white paper suggests.
I’m also running version 2.1.0, on a G5 Powermac.
Andy Mees
February 27, 2008 at 9:56 amif you are running 10.5 (Leopard) then you need to upgrade to XDCAM Transfer 2.5.1 … then you’ll get the disc back in the Finder
https://www.sony.ca/xdcamex/software/XDCAM_Transfer_2_5_1.dmg
