Activity › Forums › Apple Final Cut Pro Legacy › xdcam transfer
xdcam transfer
Posted by Dennis Allen on April 21, 2010 at 5:55 pmWhen I try to import files to FCP 7 through XDCAM transfer, no files appear on my source drive. How do I resolve this. Thanks again.
Daniel Wright replied 16 years, 5 months ago 6 Members · 7 Replies -
Steve Connor
April 21, 2010 at 5:59 pmHave you set the import location in XDCam import preferences?
Steve Connor
Adrenalin TelevisionHave you tried “Search Posts”? Enlightenment may be there.
Don Greening
April 21, 2010 at 7:34 pmBasic instructions for using XDCAM Transfer:
You can also use Sony’s XDCAM Transfer Tool as a stand alone app. Here’s how to do the initial set up. Start the program and go to preferences. There, you’re presented with 3 tabs:
• general
• cache
• importChoose “Import” and in the text field for “Import Location” type in the name of the folder on your external hard drive you want your XDCAM EX .mov files to reside. After you’ve typed the location in then click on “choose.”
Now every time you import from the cards the converted files will go to that folder. Then it’s just a simple matter of starting FCP and importing those clips into the program. They’ll appear in the Browser window.
Follow these steps for using XDCAM Transfer Tool within FCP:
Start FCP and from the File menu choose: Import>Sony XDCAM. The XDCAM Transfer Tool will start automatically and you can use it the same way as you do when it’s a stand-alone app. The difference here is that once you’ve gotten to the point where you choose “Import” in the XDCAM Window the files will be converted, imported into the perviously chosen XDCAM folder but will also appear on FCP’s Browser automatically.
– Don
Dennis Allen
April 21, 2010 at 11:20 pmI was able to successfully transfer media from an SxS card but not so with files on an external hard drive. I even tried to transfer files back to an SxS card to no avail. Kept telling me there were zero files.
Macbookpro OS X 10.6.3
2.33 GHz Intel Core 2 Duo
3G 667 MHz DDR2 SDRAM
FCP 7.0.2
XDCAM Transfer Version 2.5.1
XDCAM Clip Browser Version 2.00.01 -
Andy Mees
April 22, 2010 at 7:50 amHey Dennis
Both Sony’s XDCAM Transfer and FCP’s Log and Transfer require the source media to be contained within a valid folder structure. Sound’s like the source footage you have on that hard drive may be raw media itself rather than the whole kit and caboodle.
If you have a budget for this job, and fear this gaffe may become the norm rather than an exception, then you might want to check out Calibrated Software’s awesome MP4-EX Import component:
https://www.calibratedsoftware.com/MP4EXImport_Mac.aspHope it helps
Andy -
Brent Dunn
April 22, 2010 at 7:49 pmAlways copy the complete BPAV folder onto your hard drive. Do not take out anything, otherwise the file and transfer will not work.
Brent Dunn
Owner / Director / Editor
DunnRight Video.com -
Daniel Wright
April 25, 2010 at 8:54 pmDennis,
Sorry to be late to the party.
I would recommend updating your software. The latest version of Clip Browser is 2.6 and XDCAM Transfer is now on version 2.12.
https://support.sonybiz.ca/esupport/eSupportHome.asp
Incidentally, XDCAM Transfer does now work with MP4 files that have been pulled out of the BPAV file structure, although its better to keep it intact if you can.
