Activity › Forums › Sony Cameras › XDCam Transfer
  • XDCam Transfer
    Posted by Maggie Thistle on June 3, 2012 at 1:43 am
    I’m using XDCam TRansfer for the first time and I have a couple of questions. At the moment, I’m importing the clips into Final Cut. I can only highlight a few clips at a time as when I try to import all the clips a warning appears saying something about wrong file types. Am I doing something wrong?
    I have 3 jobs to edit and need to import clips for each job. So I’d like to clear the files from the previous job from the source window in XDCam Transfer. At the moment, I’m highlighting them and clicking remove but a box appears for every clip asking if I want to clear the cache files also. This means I have to sit through hundreds of clips, having to click ok. Is there another way to remove all the clips from my source window?
    Thanks for any help you can offer!
    Don Greening replied 14 years, 3 months ago 3 Members · 3 Replies
  • Don Greening
    June 3, 2012 at 4:30 am
    [Maggie Thistle] “At the moment, I’m highlighting them and clicking remove but a box appears for every clip asking if I want to clear the cache files also.”
    Don’t try to remove each clip separately in the middle window. Go to the left side of the screen (source window) where the folders are listed. Right or control click on one of the folders and choose REMOVE from the pop-up menu. Click OK from the ARE YOU SURE prompt and the folder will be deleted along with all the clips in the middle window that are associated with that folder.
    [Maggie Thistle] ” I can only highlight a few clips at a time as when I try to import all the clips a warning appears saying something about wrong file types.”
    Just a question first. Is your original media recorded on SXS or SDHC? I’ve never seen an issue where the non-optimized media warning has come up. Once one of the folders in the source window is highlighted all the clip icons appear in the main top window. All I do to import all clips is to highlight one then choose SELECT ALL or Cmd -A. all the clips should become selected then just choose IMPORT at the bottom right of the main window.
    – Don
    Don Greening
    A Vancouver Video Production Company
    Reeltime Videoworks
    http://www.reeltimevideoworks.com
  • Brent Dunn
    June 5, 2012 at 6:20 pm
    You need to install the Log and Transfer plugin. This will bring in the files and encode them to the proper ProRes format. It sounds like you are trying to edit the original file format, which doesn’t work well in Final Cut.
    Brent Dunn
    Owner / Director / Editor
    DunnRight Films
    DunnRight Video.com
    Video Marketing Toolbox.net
    Sony EX-1,
    Canon 5D Mark II
    Canon 7D
    Mac Pro Tower, Quad Core,
    with Final Cut Studio
    HP i7 Quad laptop
    Adobe CS-5 Production Suite
  • Don Greening
    June 5, 2012 at 10:35 pm
    [Brent Dunn] ” This will bring in the files and encode them to the proper ProRes format.”
    You mean change them to an MOV wrapper, right Brent? It will still be XDCAM EX format, not Pro Res.
    – Don
    Don Greening
    Reeltime Videoworks
