Activity › Forums › Apple Final Cut Pro › XDCam to FCPX
  • XDCam to FCPX
    Posted by Greg Ball on July 23, 2019 at 6:38 pm
    In the past I was able to use XDCam transfer to create Pro Res files that I could import into FCPX. After updating my old laptop to El Capitan, that no longer works.
    I can import the footage into FCPX with no problem, but I’m confused as to where my footage will live. I prefer to leave the footage on an External hard drive.
    My question is this. If I save the BPAV folder on my external drive, then import everything into the FCPX Library, can I still leave everything in place on my external drive? This way I don’t bloat the library.
    Any thoughts? Thanks so much!
    Greg Ball, President
    Ball Media Innovations, Inc.
    https://www.ballmediainnovations.com
    Oliver Peters replied 7 years, 2 months ago 3 Members · 2 Replies
  • Eric Santiago
    July 23, 2019 at 7:03 pm
    Just do a stress test and see how it all goes.
    Even with the updated OSX I am able to live with older codecs just as long as you have the right app to deal with them.
  • Oliver Peters
    July 23, 2019 at 7:40 pm
    [Greg Ball] “My question is this. If I save the BPAV folder on my external drive, then import everything into the FCPX Library, can I still leave everything in place on my external drive?”
    You can set your library settings to put all imported or generated media into a specific location like an external drive. The pulldown on the first choice lets you pick a location.
    Or you can choose to leave the media in place when you import new files.
    – Oliver
    Oliver Peters – oliverpeters.com
