Activity Forums Apple Final Cut Pro Legacy XDCAM sequence to flv – deinterlace?
  • XDCAM sequence to flv – deinterlace?
    Posted by Lucy Moon on February 26, 2009 at 5:09 pm
    Hello. I don’t usually make FLVs but I need to export an XDCAM 1080i50 sequence for processing with adobe media encoder.
    Where and with what should I use to remove the interlacing?
    Media Encoder doesn’t seem to have a deinterlace filter, and I never normally use FCP for exporting anything other than plain self-contained QT using sequence settings.
    Lucy Moon replied 17 years, 5 months ago 2 Members · 5 Replies
  • Stuart Simpson
    February 26, 2009 at 5:18 pm
    [Astrid Karlsson] “Media Encoder doesn’t seem to have a deinterlace filter”
    Are you quite sure about that? I’m pretty sure it does…
    -Simmie
    6 MacPros – Kona 3 & Kona LH
    1 G5s – Kona LH
    xbox360, Wii, PSP, PS3
    https://www.speak.co.uk
  • Lucy Moon
    February 26, 2009 at 5:37 pm
    Adobe media encoder Version CS4 4.0.0.374
    In which tab/area could I find it?
    thanks
  • Stuart Simpson
    February 27, 2009 at 10:45 am
    Hmmm, according to the manual CS4 automatically detects and deinterlaces interlaced material. Make of that what you will…
    https://help.adobe.com/en_US/AdobeMediaEncoder/4.0/adobemediaencoder_cs4_help.pdf
    -Simmie
    1 G5s – Kona LH
  • Lucy Moon
    February 27, 2009 at 11:19 am
    Thanks Stuart.
    Results weren’t great with Adobe Media encoder alone, so I created a compressor setting – same XDCAM compression/size etc of my sequence, but with the following settings. Took some testing but this works for me, fairly quickly, before I take the files to adobe media encoder:
    Video
    – Compression XDCAM EX 1080i50 @35Mb
    – Key frames – auto
    – No frame reordering
    – Auto data rate
    Frame Controls on
    – Output fields Progressive
    – Deinterlace – Better (motion adaptive)
    Cheers!
  • Lucy Moon
    February 27, 2009 at 11:25 am
    ps. in retrospect I realise this isn’t the right forum and appreciate it that no-one griped at me. =) problem solved anyway!
