Activity Forums Apple Final Cut Pro Legacy XDCAM sequence presets
  • XDCAM sequence presets
    Posted by Anthony Faulkner on December 15, 2009 at 12:34 am
    When i set my sequence to a XDCAM1080p30 35 VBR preset, then import footage shot to the same settings. I get message that the footage doesnt match the sequence settings. When i change the sequence to match the footage everything looks fine.
    But im wondering why have a preset if it doesnt match the footage it is preset for, seems to defeat the purpose?
    Anthony Faulkner replied 16 years, 8 months ago 2 Members · 4 Replies
  • Rafael Amador
    December 15, 2009 at 4:40 am
    Hi Anthony,there are three different XDCAM flavors;
    – XDCAM HD.
    – XDCAM EX .
    – XDCAM HD 422
    Reading through your posts, I saw that you where working with some EX-3 footage.
    Your preset shouldn’t be XDCAM, but EX.
    Both differs in the size and pixels: XDCAM is 1440×1080 HD pixels, while EX is 1920×1080 Square pixels.
    Cheers,
    rafael
    http://www.nagavideo.com
  • Anthony Faulkner
    December 16, 2009 at 2:46 am
    Hmmm
    I have FCP 6.06 and i can’t see any others other than HD.
    or pro res 422
  • Rafael Amador
    December 16, 2009 at 5:21 am
    Hi Anthony,
    I don’t remember where the EX presets come from.
    Is possible that you needs to install the SONY Transfer tool.
    You get a plugin installed in FC so you can Log&Transfer and you can “Export to XDCAM”.
    I think that is when you get the Easy Presets installed too.
    If you are unable to get them, post me and I can send them to you.
    There are 10 documents and only 4KB each.
    Cheers,
    rafael
  • Anthony Faulkner
    December 18, 2009 at 12:15 am
    Hi Raphael,
    I am running 2.7 because the 2.10 version i installed wouldnt work on Leopard. Anyway can’t seem to find any other files…
    If you could send me those presets that would be great!!
    anthony.faulkner2(at)gmail.com
    thanks again for your info and offer!
    Anthony
