Activity › Forums › Apple Final Cut Pro Legacy › XDCAM SD slug is green
  • XDCAM SD slug is green
    Posted by Francois Stark on September 7, 2007 at 7:10 am
    When I use XDCAM SD clips on a native XDCAM timeline (IMX 30mb/s), all the gaps on the timeline are green. Even when I dissolve a clip to a gap (IOW fade to black) – it fades to green! Placing a slug on the timeline – it’s green!
    The only way I can get black on the timeline now is to create a color mat and change it to black! Years ago on the Cinewave card we also had some of the formats’ gaps turn green – it must be something in quicktime that turns green when the black is not properly defined…
    Anybody else seen this?
    Systems: We find this on G5 systems running FCP 5.1.2 or 5.1.4.
    Francois
    Jeremy Garchow replied 19 years ago 3 Members · 5 Replies
  • Andy Mees
    September 7, 2007 at 12:43 pm
    repair permissions
    trash prefs
    create a new OSX user account and test in that new clean account
    kind of a scatter approach but see if any one of those steps helps
  • Jeremy Garchow
    September 7, 2007 at 1:15 pm
    Trash your ‘constant frames’ folder on your scratch disk.
  • Francois Stark
    September 19, 2007 at 12:09 pm
    Hi Jeremy
    Thanx! This did the trick.
    Regards
    Francois
  • Francois Stark
    September 19, 2007 at 12:24 pm
    Hi Jeremy
    Regards
    Francois
  • Jeremy Garchow
    September 19, 2007 at 1:03 pm
    Glad you are up and running.
    Jeremy
