Activity Forums Adobe Premiere Pro XDCAM-SD on Premiere CS5
  • XDCAM-SD on Premiere CS5
    Posted by Allby Corry on December 21, 2010 at 3:52 pm
    A few years ago I produced a video for a client in DVCam format (720×480, 4:3).
    Now he asked me this same video recorded on a XDCAM disk, but in XDCAM-SD format with the specs: IMX MXF Op1a, MPEG-2, 50 Mbps.
    How I can export in this format in CS5?
    I have a PDW-U1 XDCam drive recorder but I’m not sure how I should burn this format on disk.
    Thanks in advance.
    Cheers,
    Allby
    Criss Sei replied 13 years, 12 months ago 3 Members · 3 Replies
  • Todd Kopriva
    December 25, 2010 at 6:13 am
    The Premiere Pro CS5 (5.0.2) update added the ability to export to the MXF Op1a MPEG-2 format. It shows up as ‘MPEG2 MXF’ in the Format menu when you export.
    That’s what this line in the release notes refers to:
    “Premiere Pro CS5 (5.0.2) can export MXF files containing MPEG-2 essence items that comply with the XDCAM HD format used by such systems as Avid Unity. The standalone Adobe Media Encoder can also export files in this format.”
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Allby Corry
    December 30, 2010 at 10:28 am
    Hi Todd,
    How do I export imx 50mbps with 4 audio channels?
    The audio tab can´t be changed.
    Regards,
    Allby
  • Criss Sei
    September 25, 2012 at 6:20 pm
    I can not in any way make 4 channels of mono audio when I export are only 2 channels with mono audio and the other 2 channels without audio. Use the premiere cs6
