Activity Forums Apple Final Cut Pro Legacy XDCAM -> SD DVD – chopped off curves, end result doesn’t look good!
  • XDCAM -> SD DVD – chopped off curves, end result doesn’t look good!
    Posted by Christian Friis on June 28, 2010 at 12:40 am
    I’m working with XDCAM 1920×1080 HD4221080p25 50mb/s, square pixels, fielddominance none, aspect ratio HDTV 1080i (16:9) – These settings are automatically chosen by FCP sequenses, when adding footage to a new sequence.
    I export using compressor with these settings:
    Video Encoder
    Format: M2V
    Width and Height: Automatic
    Pixel aspect ratio: Default
    Crop: None
    Padding: None
    Frame rate: (100% of source)
    Frame Controls On:
    Retiming: (Fast) Nearest Frame
    Resize Filter: Linear Filter
    Deinterlace Filter: Fast (Line Averaging)
    Adaptive Details: On
    Antialias: 0
    Detail Level: 0
    Field Output: Same as Source
    Start timecode from source
    Aspect ratio: Automatic
    Selected 16:9
    Field dominance: Automatic
    Average data rate: 5 (Mbps)
    2 Pass VBR enabled
    Maximum data rate: 7.5 (Mbps)
    High quality
    Best motion estimation
    Closed GOP Size: 1/2 second, Structure: IBBP
    DVD Studio Pro meta-data enabled
    My end result doesn’t look good. Curves look a bit “chopped off”… I’ve read in other posts, that applying 1-2% gaussian blur, might do the trick. Others say that setting frame control to ON is needed. Frame control ON I’ve tried (as seen above), with no luck, and I’d rather not apply gaussian blur. Anyone has got the answer to how I can make good looking m2v’s with my XDCam material!?
    Thank you in advance.
    Mark Maness replied 16 years, 2 months ago 3 Members · 4 Replies
  • Rafael Amador
    June 28, 2010 at 1:51 am
    Hi Christian:
    Try setting the Resize Filter ot BETTER or BEST.
    rafael
    http://www.nagavideo.com
  • Christian Friis
    June 28, 2010 at 9:27 am
    Hello Rafael,
    Thank you very much for your post. Is this a method you’ve tried with succes? I’ve made a file with the resize parameter set to “best”, but couldn’t see any improvement in the end result.
    Some posts state that converting the material to a SD timeline in FCP does the trick, but that doesn’t see to do it for me/my material either.
    Any other suggestions?!
    Christian.
    https://www.oddresort.com
  • Rafael Amador
    June 28, 2010 at 9:57 am
    Hi Christian,
    In theory that should yields the best results in Compressor, but I’ve gave up downscaling with Compressor.
    Last week for downscaling a clip I’ve ended using SHAKE. Compressor and Purifier made a really bad job.
    Try in FC. Set “Render in High Precision ” and “Motion Effects: BEST”.
    rafael
  • Mark Maness
    June 28, 2010 at 6:46 pm
    The problem here is software down-conversion.
    Anytime you use software to down-convert any HD video, it’s not going to look as pristine as doing hardware conversion.
    Personally, I have better luck just taking the XDCAM HD file right into Roxio’s Toast and doing the one-off right from that. Most here will say that it’s not good enough and if you find that to be true for you, too. I’d say then you need to find someone who can hardware down-convert your program to a SD program that is 16×9 or letterboxed.
    _______________________________
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
