Activity Forums Apple Final Cut Pro Legacy XDCam project QT export problems
  • XDCam project QT export problems
    Posted by Jason Porthouse on October 22, 2008 at 1:06 pm
    HI all,
    This is a follow up to an earlier post, where I was getting random crashing whilst editing. I’m cutting a doc that’s mostly XDCam 1080 25p VBR, with some further material shot on an EX1 (as XDCAM) and a little as HDV. Timeline is 1080 25p easy setup.
    Running 6.04 on the latest Tiger, with QT 7.55 on an Intel 2.66 with 5 gigs RAM (installed as per Apple specs). All media is on a G-SATA 1.5TB FW800 drive. Nothing else connected via FW.
    I’m trying to export a QT of the timeline for the grade (it’s going to Baselight) and FCP quits out after a few (random) minutes of the export. Sometimes it exports OK then FCP quits, other times not.
    I’m exporting back to the FW drive.
    This problem also occurs at the production company’s own FCP suites which all run Leopard with the latest upgrades – their Macs are all Intel, but a bit newer than mine.
    Any suggestions would be helpful!!
    _________________________________
    Before you criticise a man, walk a mile in his shoes.
    Then when you do criticise him, you’ll be a mile away. And have his shoes.
    *the artist formally known as Jaymags*
    Cindy Rodriguez replied 15 years, 11 months ago 5 Members · 6 Replies
  • Dan Dennis
    October 22, 2008 at 2:39 pm
    Jason,
    Can you export to the desktop and copy to the firewire drive?
    “A generation which ignores history has no past and no future.” — Robert Heinlein
  • Jason Porthouse
    October 22, 2008 at 3:55 pm
    Hi Dan,
    No, I’ve tried different drives. There seems to be no rhyme or reason to this – but I’ll persevere!
    Jason
  • Mark Maness
    October 22, 2008 at 4:44 pm
    Jason,
    I know this may sound funny BUT… Take out 1 gig of your memory. FCP can ONLY run efficiently using 2 gig, 4 gig, 8 gig, or 16 gig. Apple has a tech doc on this and it is a fact. Trust me on this. I know that Apple put in the 5 gig… but someone at Apple was mistaken on this.
    https://support.apple.com/kb/TS1957?viewlocale=en_US
    The doc doesn’t specifically state about the multiple of 4 gig sizes… but its a true fact that odd sizes like 3, 5, 6, or 7 will cause FCP to act really strange for most people.
    Wayne Carey
    Schazam Productions
    https://web.mac.com/schazamproductions
    schazamproductions@mac.com
  • Jason Porthouse
    October 23, 2008 at 8:25 am
    Thanks for that Wayne, I’ll certainly try it. The Apple notes are clear once explained!! I thought it was symmetrical rather than symmetrical and even…
    I managed to successfully export a QT last night by placing all clips (i.e. the edited sequence) in a new 1080 50i sequence. Seeing as it was shot 25p, this doesn’t alter the look – but for some reason did enable the export.
    I had an interesting side issue with this – on exporting some slo-mo clips for a graphics pre-viz, the graphics house noticed interlacing artefacts on the video – even though it was from a 25p timeline and with 25p originating footage. Other clips in the same sequence that were not slomo’d were fine. I have a feeling that FCP isn’t rendering P, and instead rendering interlaced – and this may be throwing the exports out. Will investigate further…
    Jason
  • Andy Mees
    October 23, 2008 at 12:46 pm
    Try duplicating your sequence, then change the duplicated sequences compressor ProRes 422. Now try exporting that sequence as Quicktime Movie w/ Current Settings and Make Self Contained. That should produce an excellent high quality intermediate that the Colorist can use as source.
    Another option you might want to experiment with would be to take the original sequence and use Export > Sony XDCAM and set the export location to the desktop. If that failed, test again and see if checking the “Recompress All Frames” option would force it through.
  • Cindy Rodriguez
    August 31, 2010 at 9:15 am
    Hi
    I am editing a project using XDCAM EX 1080p25 mov files
    The sequence settings are those created by FCP when I dragged the footage into the timeline:
    Compressor HDV1080i50
    When I export a self contained QT movie the vision speeds up whilst the audio is fine.
    I think the sequence settings might be incorrect. I’ve already edited the sequence with graphics, so I was hoping not to have to convert the media to apple pro res.
    Any suggestions?
    Thanks guys.
