Activity › Forums › Sony Cameras › XDcam & PDW-F70
XDcam & PDW-F70
Posted by Justin Edwards on September 12, 2006 at 10:29 pmIm trying to get the footage I shot into Final Cut Pro 5.1 ( Latest Version) via Firewire. I keep getting the Unable to “recongize deck” . Any ideas what Im doing wrong?
JustinJustin Edwards replied 20 years ago 2 Members · 5 Replies -
Justin Edwards
September 13, 2006 at 2:02 amOk so now Im at the stage where the proxy clips are in the XDcam Viewer, But the Add function so I can Import them into FCP is not enabled. Do i need to set in and outs on every clip?
Nate Weaver
September 13, 2006 at 3:06 amYou need to select the clips you want to import. Apple-A for all.
Justin Edwards
September 13, 2006 at 1:46 pmStill will not allow me to click (Add) Do I have to have the disc in the deck?
Nate Weaver
September 14, 2006 at 2:28 amI say this with all seriousness:
I think you should read the manual.
Justin Edwards
September 14, 2006 at 1:20 pmDid! Actually read Apples (White Paper) as well. FCP is not supporting 35mbit. for at least another 30days untill 5.1.2 is released. So I Cloned the discks from Camera to deck, but recorded it at 25Mbit. Works fine now. Thanks though.
