Activity › Forums › Adobe After Effects › xdcam or dvcam better for greenscreen?
  • xdcam or dvcam better for greenscreen?
    Posted by Eric Snow on September 3, 2007 at 3:07 pm
    Hi there. Not sure if this is the right forum, but I have a keying question. I’m going to be working on a bunch of greenscreen footage in after effects soon, and I have the choice of working with either xdcam or dvcam. Although I’d usually prefer to work with anything other than dvcam for keying, I see from its specs on the internet that it’s also a 4:1:1 NTSC or 4:2:0 PAL color sampling ratio, which I think is the same as dv. So does anyone out there have any opinions as to whether XDCAM has better color than DVCAM? Just seeing what you all think. Thanks!
    Eric Snow
    snowericsnow@yahoo.com
    Brendan Coots replied 19 years ago 3 Members · 2 Replies
  • Malcolm Desoto
    September 3, 2007 at 7:12 pm
    which XD cam? Does it have variable frame rates? Can it shoot progressive frames?
  • Brendan Coots
    September 4, 2007 at 4:22 pm
    My understanding is that, unless you have a specific hardware recorder that recently came out, you are only going to get 4:2:0 from XDCAM. If those are your only choices, workflow should probably be the deciding factor, not color sampling.
    If you want 4:2:2, you should try to step up to DVCPRO-50 or DVCPRO HD, both of which are available in the Panasonic HVX200.
    Brendan Coots
    Splitvision Digital
    http://www.splitvisiondigital.com
