XDCAM only exports mono
Hi all!
As the topic suggests, when I export using mxp op1a and Xdcam HD 50 PAL (for broadcast), I only get the sound in mono, no matter what I do. I tried adding two channels of audio and panning them to each side, and a few other ideas I had, but so far nothing works. Is that format only available in mono? I t clearly says 2 channels in the audio tab when exporting.
When I tried using mxp op1a and IMX instead, it worked fine. (the reason i need XDCAM is because it´s what they request from the broadcaster)
Any suggestions on how to solve this?
