Activity Forums Apple Final Cut Pro XDCAM import/export
  • XDCAM import/export
    Posted by Eric Sternberger on February 2, 2012 at 9:00 am
    Hi Cow,
    I didn´t test FCPx yet, because of all the shortcomings regarding professional use…
    But the new Version with Broadcast-Monitoring and XML-Output seems worth a try.
    But: What about XDCAM import and export (to disc), does it work in FCP 10.0.3???
    I would need that feature in my workflow….
    Gustavo Seabra replied 14 years, 7 months ago 7 Members · 13 Replies
  • 13 Replies
  • Jeremy Garchow
    February 2, 2012 at 2:58 pm
    Not from the app. You’d still need XDCam transfer software.
  • Eric Sternberger
    February 2, 2012 at 3:09 pm
    Hi Jeremy,
    so it works like I´m used to from FCP 7 ?
    Timeline>export to Sony xdcam>render>burn to pdw-u1??
    …that would be fine
  • Jeremy Garchow
    February 2, 2012 at 3:17 pm
    There’s no export to XDCam option from within FCPX.
    You’d have to export a ProRes movie and transcode, or use a compressor setting to go to XDCam codec, then use Sony software. Have to make sure you have setup roles for mono.
  • Eric Sternberger
    February 2, 2012 at 4:36 pm
    I´m able to use compressor to make an XDCAM File from ProRes. But Compressor 3.5 ironically only gives you the option to make an XDCAM file with Stereo-Audio, which is unsupported on XDCAM disc. However you can change that manually if you need to.
    But I don´t now how to start the XDCAM-Export PLugin without FCP.
    So far, I only used Sony Transfer to get files in – but how do you export files to disc with it?
    Where is the button ;-)??
  • Jeremy Garchow
    February 2, 2012 at 5:55 pm
    [Eric Sternberger] “I´m able to use compressor to make an XDCAM File from ProRes. But Compressor 3.5 ironically only gives you the option to make an XDCAM file with Stereo-Audio, which is unsupported on XDCAM disc. However you can change that manually if you need to.”
    If you export a self contained multitrack QT using Roles from FCPX, you can choose dual mono.
    [Eric Sternberger] “But I don´t now how to start the XDCAM-Export PLugin without FCP.
    Where is the button ;-)??”
    Sorry, I think you need the XDCam Browser software which should work, although I haven’t tried it: https://pro.sony.com/bbsc/ssr/micro-xdcam/resource.downloads.bbsccms-assets-micro-xdcam-downloads-XDCAMSoftwareDownload.shtml#apps
    Jeremy
  • Eric Sternberger
    February 3, 2012 at 9:51 am
    Hi Jeremy,
    I´m sorry to say that myself, but there seems no way to output to XDCAM-Disc without final cut.
    At least not on the mac-platform. XDCAM-Browser didn´t help either.
  • Eric Santiago
    February 3, 2012 at 12:38 pm
    I didnt think this was possible at all.
    Ive always wanted to export to a virtual disc (the purple ones).
    Ive been using XDCAM for years on the Avid side and I brought this up to Avid if it was possible.
    The answer then was no.
  • Jeremy Garchow
    February 3, 2012 at 1:20 pm
    Sorry guys, I was mistaken. I thought Sony Browser could do it.
    There was supposed to Sony support (according to Apple) that was announced a while ago, but nothing has come of it.
    Must be taking longer than they thought.
    Seems weird that Sony doesn’t have a stand alone utility.
  • Eric Sternberger
    February 3, 2012 at 3:38 pm
    this whole XDCam thing is half-baked, if you ask me…
    I´m glad our clients move on faster (than Sony) and we will deliver our masters only via upload soon.
    No Disc or Tape-fuss anymore… and expensive units that are crap and useless in the first place
  • Steve Connor
    February 3, 2012 at 3:49 pm
    [Eric Sternberger] “his whole XDCam thing is half-baked, if you ask me…”
    Very true, it was always going to be a transitional format.
    Steve Connor
    “FCPX Agitator”
    Adrenalin Television
