Activity Forums Avid Media Composer XDCAM import to AVID 5 via PDW U1
  • XDCAM import to AVID 5 via PDW U1
    Posted by David Koch on March 22, 2012 at 5:02 pm
    Hello!
    I am preparing myself to work with XDCAM files and the PDW U1 drive. So i have a question about this workflow. I did a research on the internet and it seems quite simple so far: Connect it with – in my case – the Mac and go for it. But i really would like to know what is exactly going to happen then? Will the the files be automatically converted to .mxf and copied in the “Avid MediaFiles” directory? How do i handle them and finally export them? Anyone has made experiences so far?
    Cheers,
    David
    Richard Sanchez replied 14 years, 5 months ago 3 Members · 4 Replies
  • Richard Sanchez
    March 22, 2012 at 6:45 pm
    You need to download the U1 driver software, as well as the Sony XDCAM AMA plugin. They will not be automatically copied. AMA will generally automatically link to the files. From there, you can transcode them to your offline format. In my case, we’ve been transcoding them to 8:1m for offline.
    This is a particularly useful tutorial on the basic XDCAM workflow with AMA. https://www.youtube.com/watch?v=ABQ4uaEDSgc
    Richard Sanchez
    Los Angeles, CA
    “We are the facilitators of our own creative evolution.” – Bill Hicks
  • Eric Santiago
    March 23, 2012 at 1:24 am
    From past experience with the PDW U1, I would rather copy the XDCAM disc (the whole disc) to a drive then access.
    We had some issues with AMA not recognizing the same disc during re-ingest.
    Got rid of the PDW and stayed with the bigger XDCAM decks.
  • David Koch
    March 23, 2012 at 10:10 am
    Thanks Richard, thanks Eric!
    So i am not going to use the proxy method, but work with the full-res material. Is there a chance to wrap the data from the disc into a .mxf file?
  • Richard Sanchez
    March 23, 2012 at 4:05 pm
    Yes. Follow the tutorial, except instead of consolidating the proxy by selecting “Most Compressed” in your AMA Consolidation settings, set it to “Highest Quality”
    Richard Sanchez
    Los Angeles, CA
