Activity › Forums › Avid Media Composer › XDCAM import problem
  • XDCAM import problem
    Posted by Stig Olsen on April 22, 2014 at 10:44 am
    I just got some XDcam material on an external HD.
    Its folder structure is as following; PROAV/CLPR/C001/C001A01.mxf and so on.
    I have the latest AMA drivers, and I have tried both AMA linking and regular import. Nothing works. Any idea?
    Stig
    AVCHD MSP Plug-In Avid Technology, Inc. 1.3
    AVCHD MVP Plug-In Avid Technology, Inc. 1.3
    Avid MXF MSP Plug-In Avid Technology, Inc. 1.1
    Sphere (5975 1.3.6367424) Avid Technology, Inc. 1.1
    QuickTime Plug-In Avid Technology, Inc. 1.3
    AS-02 Plug-In Avid Technology, Inc. 1.2
    AS-11 Plug-In Avid Technology, Inc. 1.0
    MSP_MXF Plug-In Avid Technology, Inc. 1.9
    MVP_MSP_SonySRDeck_64bit Sony Corporation 2.2013
    WaveAiff Plug-In Avid Technology, Inc. 1.0
    MVP_MSP_SonyXDCAMEX_64bit Sony Corporation 1.7053
    MVP_MSP_SonyXDCAM_64-bit Sony Corporation 3.2011
    Michael Phillips replied 12 years, 5 months ago 2 Members · 1 Reply
  • Michael Phillips
    April 23, 2014 at 11:33 am
    I usually try linking via clip first before folder to make sure the correct Sony AMA plug-in is being used. So in yor example, use the link to file and select “C001A01.mxf ” directly with each of the plug-ins. Once you know you can link to it, note which one you are using then use the “folder” version of the AMA plug-in and work your way backwards in the folder structure until it works. There is only one level of hierarchy that will work and I never remember which one, so I do the different levels until it does. My guess is either the PROAV or the CLPR folders. Also make sure there are strange characters or slashed (/) in any of the folder names, but from your example, it does not seem to be the case.
    Michael
