Activity Forums Apple Final Cut Pro Legacy XDCAM IMPORT ERROR TO FCP
  • XDCAM IMPORT ERROR TO FCP
    Posted by Annu Lilja on September 2, 2008 at 9:42 pm
    Hi.
    I’m trying to import an XD CAM clip to FCP with XDCAM Transfer. The clip is actually more than 50 minutes long, which I can view with XDCAM Browser. But as i try to import the clip, it seems like it is only 11 minutes long. Also, in the middle of importing, I get this error message:
    Import Error
    The clip could not be imported. There may be insufficient disc space.
    Although I have more than enough disc space.
    Any useful hints?
    Annu
    Andy Mees replied 18 years ago 4 Members · 8 Replies
  • 8 Replies
  • Chris Borjis
    September 3, 2008 at 12:16 am
    trash preferences.
  • Andy Mees
    September 3, 2008 at 12:30 am
    Well at the risk of being painfully obvious … have you got enough disk space?
    Where are you importing the clip to? Internal hard drive, dedicated media drive or ? You target the Import directory in the XDCAM Preferences which by default is set to the ~/Movies folder. You will probably want to change this to your external. What version of XDCAM Transfer are you using? Versions prior to 2.x had a major bug which could result in your hi res imports being directed to the otherwise hidden /Volumes directory if you inadvertently launched XDCAM Transfer without the target drive mounted.
  • Stuart Simpson
    September 3, 2008 at 8:31 am
    Which version off the XDCAM transfer software are you using? The most recent version is 2.7.1
    -Simmie
    3 MacPros – Kona 3 & Kona LH
    2 G5s – Kona LH
    2 G4s – Cinewave
    xbox360, Wii, PSP, PS2
    https://www.speak.co.uk
  • Annu Lilja
    September 3, 2008 at 11:59 am
    Yes I have disc space. I am importing it to an external hard drive.
    I’m using version 2.5.1.
  • Annu Lilja
    September 3, 2008 at 12:00 pm
    I’m using version 2.5.1. Do you have a link to the latest version? Would it make a difference?
  • Annu Lilja
    September 3, 2008 at 12:04 pm
    How do I do that? I’m new to FCP.
  • Stuart Simpson
    September 3, 2008 at 3:27 pm
    [Annu Lilja] “Would it make a difference?”
    It might fix your problem – you can download it from Sony. Try http://www.sonybiz.net
    -Simmie
    2 G5s – Kona LH
    2 G4s – Cinewave
  • Andy Mees
    September 4, 2008 at 4:33 am
    How much space do you have on your External drive? Does that sound about right?
    How much space do you have on your built-in system drive? Does that sound about right?
    Go to your XDCAM Transfer menu > Preferences window >> Import tab … what path is shown for the Import Location?
