Activity › Forums › Apple Final Cut Pro Legacy › XDCAM > HDCAM Layoff??
Posted by Lisa Rolley on June 22, 2009 at 7:30 pmHey Gang,
I have used XDCAM in the past but never had to layoff to HDCAM – the footage is 29.97 upper fields xdcam footage – my sequence in fcp automatically set to the same when i dropped in my first clip (clicked yes) as well i also set the reder control to ProRes as i had seen that being instructed in the past…just now i have to layoff to an hdcam tape and i am wondering if i need to kick out a qt file at prores and the bring it into an 8 or 10 bit uncompressed HD sequence for layoff.
Would it also be possible to just copy and paste from one sequence to the other??
any advice would be great
thanks
LisaLisa Rolley replied 17 years, 3 months ago 4 Members · 10 Replies -
Lisa Rolley
June 22, 2009 at 7:39 pmwe have all blackmagic HD & HD extreme cards…so as long as i render at proRes i should be fine to layoff in that codec or no??
I was under the impression that something about the GOP in XDCAM is why you render out ProRes – regardless i am wondering also if in the sequence we can just switch the compressor setting to uncompressed 8 bit and then just re-render ?
Walter Biscardi
June 22, 2009 at 7:45 pmif you have an AJA Kona board you can lay to HDCAM tape directly from the XDCAM timeline.
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
Walter Biscardi
June 22, 2009 at 7:47 pm[Jeremy Garchow] “No, if you are getting rt playout from your Kona, there’s no reason to recompress. “
She’s using BMD, not AJA unfortunately.
Walter Biscardi
June 22, 2009 at 7:55 pm[lisa rolley] “we have all blackmagic HD & HD extreme cards…so as long as i render at proRes i should be fine to layoff in that codec or no?? “
Somebody else will have to answer that. We don’t touch blackmagic stuff here.
Jeremy Garchow
June 22, 2009 at 7:58 pmNo, if you are getting rt playout from your Kona, there’s no reason to recompress.
Jeremy
Lisa Rolley
June 22, 2009 at 8:13 pmhey guys
thanks for the fast responses – you rock!so just to be clear on this you are saying to set render tab to prores and then layoff the sequence as is to hdcam – no need to change to uncompressed 8 bit – also would it hurt in any way to kick out the pro res qt and bring back into an 8 but uncompressed hd sequence or would there just be no difference and an unnecessary extra step of re compressing?
many thanks
Lisa : ) -
Jeremy Garchow
June 22, 2009 at 8:17 pmWoops, sorry, my browser wasn’t refreshed when responding.
I would imagine Blackmagic would be the same way. No reason to recompress.
Jeremy
Jeremy Garchow
June 22, 2009 at 8:18 pm[lisa rolley] ” would there just be no difference and an unnecessary extra step of re compressing? “
Yep, no reason to recompress.
Jeremy
Shane Ross
June 22, 2009 at 8:18 pmShould be able to output with the BMD just the same. No render needed. But even with a Kona or MXO2 I’d render as prores using the render control settings.
Shane
Read my blog, Little Frog in High Def -
Lisa Rolley
June 24, 2009 at 7:50 pmHey Guys!!
So its time to layoff and I have a couple questions because another editor and I are noticing little jagged lines along the red lines in an actor’s shirt collar – This can be seen i nthe original files created with the xdcam transfer tool Sony provides – when viewed in qt we see that issue in the original transferred files…for broadcast HDCAM layoff is there anything that can be done to remove these jagged lines??
I just did a test export qt and in qt pro it says its XDCAM and i guess i was under the impression that when you switch the render tab to ProRes that when you render the sequence and kick out a QT file it would be in the ProRes codec – CLEARLY i was wrong…any thoughts on how to proceed in trying to clean up these little teeth in the red and also layoff to hdcam accordingly??
thanks
Lisa
