Activity › Forums › AJA Video Systems › XDCAM HD Settings?
  • Mactrix
    November 21, 2006 at 8:04 pm
    I just rendered out a XDCAM HD 35 Mbit clip out of After Effects.
    Composition is set to 1920 x 1080 with 25 fps.
    Render Settings: Best Settings
    Output Module -> Format Options: XDCAM HD 1080p25 (35 Mb/s VBR)
    Like this it worked on my setup. In Compressor I would create a similar
    preset …
  • Mark Maness
    November 21, 2006 at 8:09 pm
    [mactrix] “I just rendered out a XDCAM HD 35 Mbit clip out of After Effects.
    preset …”
    Now, you’re on the smae page as I am. BUT in FCP if I want to capture something into the XDCAM HD codec such as HDV, upconverted Digibeta, or any signal that I wish… it comes out really bad. It skips frames, looses sync and overall poor picture quality.
    That is my question that I have been asking. Has anybody gotten this to work?
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Mactrix
    November 21, 2006 at 8:19 pm
    I know English is not my mother tongue but I think that I clearly pointed out that
    CAPTURING INTO XDCAM HD OR HDV DOESN’T WORK IN FCP
    You can capture native HDV from a HDV source that is connected via FireWire.
    You can import native XDCAM HD 35 MBit from a XDCAM source that is connected
    via FireWire using the Sony XDCAM Transfer software and File Access Mode.
    You CANNOT capture into HDV nor XDCAM HD via a capture card.
  • Mark Maness
    November 21, 2006 at 8:46 pm
    [mactrix] “You CANNOT capture into HDV nor XDCAM HD via a capture card.”
    Yes… I am fully aware of what you are talking about BUT this is the last piece of the puzzle for AJA to have a complete product.
    Th reason I bring this up is the fact that our main camera is XDCAM HD and our secondary cameras are HDV. I need a way to get HDV into XDCAM HD and I can capture directly into XDCAM SD from HDV but not into XDCAM HD. And please, let’s not get into the quality difference discussion. I am aware and for our budget, the qualities are extremely similar for money.
    Currently, I have to work in the DVCProHD codec and this makes using the Sony Transfer software difficult to use. My point is to perfect my workflow into the best possible for the quality and file sizes. XDCAM HD has smaller file sizes with quality that rivals HDCAM. I need a way to conserve space.
    Wayne Carey
    Schazam Productions
  • Mactrix
    November 21, 2006 at 9:01 pm
    AJA offers yet comprehensive support for various codecs.
    It is very time consuming for manufactures to support all
    these different formats. However AJA supports yet HDV
    for video monitoring but capturing is a totally other story
    due to the MPEG-2 GOP structure.
    It’s not up to AJA to offer you a customized product. It’s
    up to you to customize your workflow.
    Go and buy a Convergent Design HDConnect SI HDV to
    HD-SDI cross-converter. This will solve your problem.
    And alternatively why don’t you just mix your formats inside
    one timeline? Set it to unlimted realtime to get at least a
    realtime preview …
Page 2 of 2
