Activity › Forums › Apple Final Cut Pro Legacy › XDCAM HD: Import from camera?
  • XDCAM HD: Import from camera?
    Posted by Matt Larson on January 12, 2007 at 6:54 pm
    Quick question: Can you Import XDCAM HD material directly from the 350 camera using the Sony Transfer software? I’ve done it from a demo deck before, but we are going to be renting the camera and I need to know if I should rent a deck as well.
    And an extra 50 points if you know if the 350 has HD-SDI out-
    Thanks-
    Toby Dalsgaard replied 19 years, 8 months ago 4 Members · 7 Replies
  • 7 Replies
  • Toby Dalsgaard
    January 12, 2007 at 7:32 pm
    Yes
    No
  • Toby Dalsgaard
    January 12, 2007 at 7:33 pm
    Sorry..yes you can import from a cam, and no the 350 doesn’t have HD SDI out.
  • Matt Larson
    January 12, 2007 at 8:23 pm
    Thanks-
  • Mark Maness
    January 12, 2007 at 8:25 pm
    [Proper Modulation] “Sorry..yes you can import from a cam, and no the 350 doesn’t have HD SDI out.”
    Bud, you mistaken on the HD-SDI output. Its right on the back plane of the camera, right next to the XLR inputs.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Mark Maness
    January 12, 2007 at 8:27 pm
    Matt…
    The XDCAM HD 350 camera HAS an HD-SDI output on the back of the camera, next to the XLR connectors. Now, the 330 doesn’t have this option.
    If you rent this camera, its a good as a deck for your purposes.
    Wayne Carey
    Schazam Productions
  • Steve Connor
    January 12, 2007 at 9:18 pm
    I’ll confirm that! It is the 330 that doesn’t have HD-SDI
  • Toby Dalsgaard
    January 15, 2007 at 5:12 pm
    Sorry man. I feel bad for disseminating this false info. We have a 330. Sorry….
