Activity Forums Avid Media Composer XDCAM HD Import Error
  • XDCAM HD Import Error
    Posted by Dale Dingler on November 25, 2008 at 9:50 pm
    I am trying to import XDCAM HD into a MC 3.0.5.
    The first clip imports fine, but after that I get a “bad allocation” error. If I restart the avid, I can import the next clip, then I get the error message again. This happens with both the PDW-U1 drive and the PDW-F75 deck.
    If I try to import from a sequence, none of the clips will import.
    Any help would be appreciated.
    Thanks.
    Joe Womble replied 17 years, 9 months ago 2 Members · 1 Reply
  • Joe Womble
    December 1, 2008 at 7:23 pm
    Dale,
    Are you working in Picture Cache Record Mode, Interval Record Mode, or VFR (Variable Frame Rate) Mode (UCC/OCC – Undercrank/Overcrank)? Avid does not batch import these modes. Otherwise, is the firmware current for the Sony decks?
    Regards,
    Joe Womble
