Activity › Forums › Apple Final Cut Pro Legacy › XDCAM HD conversion for client to see
  • XDCAM HD conversion for client to see
    Posted by Jason Blalock on January 8, 2011 at 10:49 am
    My client asked for “1920 x 1080 uncompressed” delivery of the show I’ve edited, so I exported “using sequence settings,” but they just wrote to say they can’t see the video. Shoulda seen that coming…
    I shot Sony XDCAM HD 1080 24p, and imported using that codec. Is there a more universal HD codec that people without Final Cut and the Sony plug-ins can see? Maybe people using Windows?
    I can make it SD as well, but HD is preferred.
    Jason
    Andy Mees replied 15 years, 8 months ago 5 Members · 5 Replies
  • Jerry Hofmann
    January 8, 2011 at 4:25 pm
    I think the question that needs to be answered is what do they want to use this for? Just viewing? or?
    If they just want to look at it, maybe just an mp4 will do the trick… Just make it full sized.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    Current DVD:
    https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
  • Russell Lasson
    January 8, 2011 at 9:06 pm
    If they have the latest QuickTime loaded, then prores will work. Prores Proxy is quite small and user friendly. You could also use h264, but as Jerry says, it really depends on how they’re going to use it.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
  • Andy Mees
    January 9, 2011 at 8:03 am
    [Jason Blalock] “My client asked for “1920 x 1080 uncompressed” delivery “
    [Jason Blalock] “I shot Sony XDCAM HD 1080 24p, and imported using that codec …”
    [Jason Blalock] “…I exported “using sequence settings””
    So it sounds like they asked for delivery as “Uncompressed” but you sent them XDCAM HD … you could re-export using Apple’s Uncompressed codec and send them that, or as Russel and Jerry already suggested, maybe a good idea to double check with the client which codec it is that they want (or need).
    Cheers
    Andy
  • Sam Cole
    January 9, 2011 at 11:10 pm
    [Andy Mees] ” you could re-export using Apple’s Uncompressed codec”
    that always brings a smile to face when I read that the words “uncompressed codec” because ‘uncompressed’ means “no codec”.
    But what Andy says is correct – you supplied a compressed format when they asked for uncompressed. Unfortunately, be prepared for a much larger file size!
    Sam Cole
    On line Mastering Facility
    FCP, Avid, Adobe
    Sydney, Australia
  • Andy Mees
    January 9, 2011 at 11:52 pm
    [Sam Cole] “‘uncompressed’ means “no codec”.”
    Actually, Apple’s “Uncompressed” codec is indeed a codec … in Quicktime, if you seriously want “no codec”, then you should set the compressor to “None”. (Jason: don’t set your compressor to None, nobody uses None).
    Cheers
    Andy
