Activity Forums Apple Final Cut Pro Legacy XDCAM HD 330. Does it output audio with the firewire video?
  • XDCAM HD 330. Does it output audio with the firewire video?
    Posted by Dan Riley on February 2, 2007 at 9:06 pm
    I’m dealing with a one day shoot that will use the XDCAM HD 330.
    My project is SD, so I want DV or DVCAM out and cropped.
    I asked the shooter if I can get DV out via the firewire port LIVE
    into my Macbook Pro and recorded by FCP. He tried it with his PC
    and he says there is only video, no audio. He also says if he
    plays the disk back after the fact, the firewire out also does not have
    audio. Is this really the case?
    He says I should do a file transfer to my laptop, but I don’t want to deal with
    IMX files or whatever Sony outputs. I’m not doing HD work and don’t
    want to deal with odd files at this point.
    What do you guys know about the firewire output of this camera?
    Do I have to use the file transfer method with this camera?
    Dan
    Dan Riley replied 19 years, 7 months ago 5 Members · 11 Replies
  • 11 Replies
  • Mark Maness
    February 2, 2007 at 9:53 pm
    Let first ask this…
    Why are you using an HD camera to do a SD project if you have no reason for using HD?
    If you want an SD signal, you need to record in DVCAM mode with the camera, either cropped or letterboxed. At that point, when you transfer the footage as DV, you’ll get your audio with your video files using the Sony transfer software.
    It will do HD, DVCAM, or DV. It will import the audio tracks you select in your preferences.
    _______________________________
    Wayne Carey
    Schazam Productions
    http://www.schazamproductions.com
  • Chris Borjis
    February 2, 2007 at 10:07 pm
    [Wayne Carey] “Why are you using an HD camera to do a SD project if you have no reason for using HD?”
    One I reason I would do that is to get a better looking final image.
  • Dan Riley
    February 2, 2007 at 10:12 pm
    I have no choice in the matter of the camera for this one day of testimonials.
    I’m just trying to make it work.
    So, if the shooter sets the camera to DV, 4 by 3, will I have audio and video
    out LIVE through the firewire port while he is recording? If not, will I have audio and video
    out the firewire port when he plays back the disk AFTER recording?
    Or are you saying this camera does not output audio and video through
    the firewire port that can be recorded as a DV or DVCAM stream?
    It only outputs files via firewire? And those files can be DV quicktime files?
    And I have to have Sony Software installed to use them?
    Dan
  • Mark Maness
    February 2, 2007 at 11:01 pm
    [Danrnw] “So, if the shooter sets the camera to DV, 4 by 3, will I have audio and video out LIVE through the firewire port while he is recording?”
    I can’t answer this to be perfectly honest, but are you trying to setup a “live” camera shoot?
    [Danrnw] “If not, will I have audio and video out the firewire port when he plays back the disk AFTER recording?”
    Well…. Yeah… How else would you be able to batch digitize footage? Besides using the Video and Audio Out connectors.
    [Danrnw] “Or are you saying this camera does not output audio and video through the firewire port that can be recorded as a DV or DVCAM stream?”
    AGAIN… Yes, this camera does output via firewire in order for you to batch digitize…
    I have to ask this… Why are you trying to record thru the camera? To what? You can record to DVCAM onto XDCAM HD discs. Its 25 m/bit stream in actual DVCAM codec, of which, you can batch digitize in FCP using firewire or composite video and audio out connectors.
    [Danrnw] “And those files can be DV quicktime files? And I have to have Sony Software installed to use them?”
    Yes, the files are DV Quicktime files AFTER you use the Sony Transfer Software. You do not have to have this software installed IF you are going to use the DV Easy Setup. If you use this, just connect your firewire connection and batch capture as you would with a DV machine. The Sony transfer software is the much better option to use since you can pull files off of the drive faster than batch capture, but if you are more comfortable with the standard way of doing this…. albeit… do it the way you like.
    Wayne Carey
    Schazam Productions
  • Dan Riley
    February 2, 2007 at 11:31 pm
    I guess I’m not being very clear.
    This shoot is in Palm Springs. I’m in Seattle.
    I don’t have a way to use the disks here in Seattle.
    When the shoot is finished, I need to have video and audio
    somewhere in a form I can take back and use at my edit suite that’s an
    uncompressed DigiBeta house, SD only (for now).
    What I was thinking was, since I have FCP on my Macbook Pro, could I
    “capture now” from the firewire connection to that camera with DV?
    Could I do this during the actual interviews or do I have do this after the fact,
    using the disks playing back in to FCP? I do not care about timecode.
    If it starts over every time that’s ok in this case. It’s only one camera.
    I assumed, like all other cameras with firewire ports, that you can either
    get audio and video out the camera to FCP EtoE, recording or not,
    or you could play back the disk out firewire and record it to FCP that way.
    But the shooter said when he tried it on his PC (not a Mac) he did not
    have audio, only video. So I figured this was a setting he had wrong.
    That’s all I’m asking here. Can you see SD video & audio without the camera
    recording, or does it only work with the disk playing back?
    And if the guy who owns the camera can’t get audio out via firewire,
    is this his fault or is there some problem with the camera and audio?
    Dan
  • Steve Eisen
    February 2, 2007 at 11:54 pm
    Don’t confuse yourself. Record your footage onto XDCAM Disc using DVCAM mode. You can connect the camera to your MB Pro via firewire and transfer the footage into FCP. It is that simple. And YES, you will get both audio and video.
    Steve Eisen
    Eisen Video Productions
    Director-At-Large
    Chicago Final Cut Pro Users Group
  • Dan Riley
    February 3, 2007 at 12:26 am
    Thanks.
    I figured it was as simple as other cameras. But not having actually used it . . . .
    I called Bexel here in Seattle and they now have the PDW F70 deck available too.
    So if the FCP-MBP doesn’t work quite right, I can always rent that deck.
    It has SDI out too. But at $300 a day I’d rather not have to do it for this one interview.
    As far as the XDCAM HD goes, I WANT to start using and trying it out when we go HD,
    but we haven’t done that yet.
    Dan
  • Steve Eisen
    February 3, 2007 at 1:06 am
    This article can help you out.
    https://seminars.apple.com/seminarsonline/fcssony/apple/
    Steve Eisen
    Director-At-Large
  • Dan Riley
    February 3, 2007 at 2:08 am
    Thanks Steve, but I’ve read all about the camera. I’ve been to the Apple/Sony
    road show etc. My question was just this…..will the camera output video and audio
    when it is not recording, out via firewire, SD- DV, so I can record it in FCP with
    “capture now”. So far no one has told me yes or no.
    I’ve decided to rent the deck and capture the disk playback from SDI out
    into FCP. I will also try a dump of the files and play around with that process too,
    but that will only be for testing. As long as I can get SDI out of that deck,
    I’ll be happy.
    Dan
  • Andy Mees
    February 3, 2007 at 2:43 am
    the answer is “yes”
