Activity Forums Compression Techniques XDCAM –> H.264 Stutter
  • XDCAM –> H.264 Stutter
    Posted by Glenn Takakjian on March 30, 2011 at 3:23 am
    I have been using XDCAM HD422 through Final Cut. Everything looks and works great. I Export a sequence from FCP. Then in Compressor I do a conversion to H.264, best settings… Current FPS, automatic Keyframe and Automatic Data Rate. No Resizing. Same size (1920×1080)
    The original exported movie plays perfectly. The H.264 has all sorts of stuttering. Never seen any problems like this with other conversions to H.264.
    Has anyone else noticed this problem. Have a a solution? Thanks!
    TAK
    Craig Seeman replied 15 years, 5 months ago 3 Members · 2 Replies
  • Jeff Greenberg
    March 30, 2011 at 10:59 am
    [Glenn Takakjian] “Keyframe and Automatic Data Rate”
    I’m not a fan of the ‘automatic’ anything on a codec. See what the data rate is…
    Then run it through with the Youtube preset – you’ll get a file that absolutely should play back, look good, etc.
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    Come See me speak at NAB!
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Craig Seeman
    March 31, 2011 at 8:06 pm
    Automatic Data Rate may well result in a data rate too high for some computers to play without stuttering. The encode may be fine but it may just be too high for smooth playback.
