Activity › Forums › Adobe Premiere Pro › xdcam footage will not conform correctly
  • xdcam footage will not conform correctly
    Posted by Jake Williams on June 19, 2009 at 1:39 pm
    Hi
    I have some xdcam footage that was used in a project. I worked on it last week then put it aside until yesterday. When I opened the project premiere conformed the files again as expected. However there is a problem between the master clips and the clips on the timeline; Within the bin the clips appear in full with audio and video. In the timeline the clip does not display audio or video and appears with slash lines through like a freeze frame. Is there any way to force premiere to re-conform the files? Could that fix what appears to be a linking issue within the project? Any input is appreciated. Thanks.
    Jake Williams
    Premiere CS4
    Win XP
    Quad core, 4GB RAM
    Tim Kolb replied 17 years, 3 months ago 2 Members · 1 Reply
  • Tim Kolb
    June 21, 2009 at 5:24 pm
    What happens if you right-click on a clip on the timeline and ask it to “reveal in project”?
    I’m not sure what you’re referring to when you say “slashed lines”… If the clip on the timeline has diagonal lines on it…I believe that means the track is locked. You may want to check this…
    The clip not showing video or audio might indicate that the clip is ‘disabled’? If you right click on the clip, you should have the ability to ‘enable’ it…
    Dunno why the project would do these things…sounds like a possible bug, but hopefully one or more of these items would at least fix your problem.
    Do you have any other video-specific hardware on the machine? Have you added any since you last saved the project?
    TimK,
    Director, Consultant
    Kolb Productions,
