Activity Forums Adobe Premiere Pro xdcam files change after export
  • xdcam files change after export
    Posted by Haji Man on August 19, 2012 at 9:41 am
    Hi!
    I’m working with premiere cs5 windows 7 and I have this repeating problem- after editing a project long time I’m exporting movie and I see some different result- I found the file that causes the problem so on the timeline everything is as it should be but when I export something else from that file is rendered.
    like I said it’s not the first time and usualy I solve it by opening a clean project and import the project so it will relink, or I duplicate the “damage” file, give it a new name and replacing it, or I open the project in cs4… but now it wont work and if I change the name and replace the file the file goes offline and it’s the same file
    if anyone knows this problem…? I cant work like that- most of the projects it’s o.k. it happens mostly with one photographer with xdcam ex 35 files- but the problem is about the path/direction of the files so maybe it’s combination of files with same name?
    thanks
    Haji Man replied 14 years, 1 month ago 1 Member · 0 Replies
  • 0 Replies
