Activity Forums Apple Final Cut Pro Legacy XDCAM field flicker on digibeta recording?
  • XDCAM field flicker on digibeta recording?
    Posted by Kevin Maguire on October 16, 2008 at 12:36 pm
    Hi there,
    I’ve just ETT a 1 hour prog onto a Sony M2000 and there is a field flicker problem on playback.
    The original footage came from XDCAM and was interlaced. I frame-rated the sequence by changing the sequence settings from ‘field’ to ‘frame’.
    Playing from FCP to my Sony broadcast monitor everything looked framed and flicker-free, but the playback from digi (when jogged) revealed a difference between the two fields (sharp then soft), causing the field flicker.
    The easy solution is to put a max deflicker filter over the whole timeline, but I can’t understand where the problem is coming from.
    Surely if I deinterlace, one set of fields is duplicated, and the digi recorder shouldn’t see a difference.
    I did a test using a sequence set to fields, and putting the deinterlace filter over the footage, but the result was exactly the same; sharp/soft.
    So, is there a known issue with the compression on XDCAM, causing this kind of problem?
    Thanks in advance.
    FCP 6.0.2
    Mac OS 10.5.2
    2 x 2.8 Quad core Intel
    6 GB RAM
    eSATA 3Tb G-Raid
    BM Decklink HD Extreme 2
    Decklink 6.7.2
    Chris Borjis replied 17 years, 11 months ago 2 Members · 3 Replies
  • Chris Borjis
    October 16, 2008 at 5:09 pm
    [Kevin Maguire] “The original footage came from XDCAM and was interlaced. I frame-rated the sequence by changing the sequence settings from ‘field’ to ‘frame’.”
    why did you frame-rate it and not leave it interlaced?
    changing that usually introduces problems down the line later.
    Better to just leave interlaced…as interlaced unless your client requires a 24psf deliverable.
    if you change it back to fields as it was originally it should be fine.
  • Kevin Maguire
    October 16, 2008 at 7:59 pm
    The director wanted it frame-rated for a ‘film’ look.
  • Chris Borjis
    October 16, 2008 at 9:04 pm
    It can look like film with 24p cadence and all and still be interlaced.
    It will have to be if you are laying back to Digibeta…its not progressive.
