Activity Forums Sony Cameras xdcam ex3’s mp4 into fcp7
  • xdcam ex3’s mp4 into fcp7
    Posted by Tiago Bartholo on January 31, 2010 at 7:39 pm
    HI,
    ARE PLUGINS NECESSARY TO IMPROVE THE WORKFLOW BETWEEN A XDCAM EX3’S MP4 FILES WHEN USING FINAL CUT PRO 7?
    I HAVE TRIED SOME THINGS WHICH DIDN’T WORK SO FAR, AND CONVERTING ALL FILES IS NOT AN OPTION. I ASSUMED THE WORKFLOW BETWEEN THE TWO WOULD JUST FLOW. SINCE THAT IS NOT THE CASE, ID APPRECIATE IF ANYBODY WOULD LET ME KNOW OF ANY PLUGINS THAT COULD MAKE THAT HAPPEN.
    THANK YOU,
    JK
    Don Greening replied 16 years, 7 months ago 2 Members · 1 Reply
  • Don Greening
    January 31, 2010 at 7:51 pm
    Are you asking about editing .mp4 files natively in FCP? You can purchase a plug-in from Calibrated Software that will allow you to do this so you don’t have to convert the files to .mov using Sony’s transfer Tool.
    https://www.calibratedsoftware.com/MXFImport_Mac.asp
    And turn off your caps lock key when posting. It’s like yelling at everybody.
    – Don
