Activity Forums Apple Final Cut Pro Legacy XDCAM EX to SD
  • Posted by Tel Jaba on June 11, 2009 at 12:24 pm
    hey guys,
    working with XDCAM EX 1080 25p
    final output should be SD
    client might want one day to have HD copy as well
    my question is :
    what should I set my easy set up to? PAL DV? and what should be my workflow
    Shane Ross replied 17 years, 3 months ago 3 Members · 4 Replies
  • Shane Ross
    June 11, 2009 at 5:58 pm
    What format is your SD deliverable? Tape? file?
    Edit in an HD sequence….settings that match your clip settings. Then when you are done you can downconvert. HOW? Depends on your deliverable.
    Shane
  • David Di francesco
    June 11, 2009 at 7:26 pm
    Your easy setup should be HD, 25fps, XDCam EX 1080p25 VBR.
    Use the log and transfert tool to transcode your footage to Pro Res 422 (I don’t think FCP supports the XDCam EX footage natively, but I’m not 100% on that, it may just be a re-wrap to .MOV files like with P2 footage, which would be much faster).
    Cut your edit in HD and render out a downconverted SD Pal version when you are all done for final delivery. I personnaly find the software downconverts in FCP to be quite soft, so if you could use a software like After Effects or something to do the downconvert, or better yet playout of say an AJA Kona 3 card directly onto an SD tape, even better.
    David D.
  • Tel Jaba
    June 11, 2009 at 7:32 pm
    Tapes and DVDs
    so should I work in ProRess then?
  • Shane Ross
    June 11, 2009 at 7:37 pm
    That or Native XDCAM. But the render times will kill with XDCAM. I’d go for ProRes.
    How will you make the tapes? Have a capture card? It will downconvert in real time. The DVDs made in DVD SP? Compressor will compress the HD footage to normal SD DVD.
    Shane
