Activity › Forums › Sony Cameras › xdcam ex or xl-h1
  • xdcam ex or xl-h1
    Posted by Anonymous on December 20, 2007 at 2:31 am
    Hi all,
    i’m choosing netween the xl-h1 and the xdcam ex
    so far i have some conclusions
    xl-h1:
    +gen+tc in (for use with my lockit)
    i like the picture don’t like the hdv format slow rendering
    tape based
    sdi-out direct into hdextreme
    true 25 fps?
    easy cheap backup media
    xdcam ex
    no tc or lanc
    true 1920×1080 cmos
    under over crank
    true 25 fps?
    fast transfer when used with a expressslot card but much slower with supplied usb2 card reader?
    no good backup methode?
    i think both have the hd-sdi out before the compression?
    what do you think?
    i like to do blue/green screen work using the hd-sdi out or on recorded material when in the field
    i have a 744t and a lockit so locking tc would be a big plus
    i think i will be using the proress hq 422 a lot for speed /storage sake would recording from the hd-sdi out from prerecoded material (hdv xl-h1 or the mpeg2 into mpeg4 container xdcam)
    if recording from the hd-sdi out from the xl-h1 tape would the tc still be in the file? kristian oonce told me i needed premiere pro for that (rp-168 protocol if i remeber)
    i.o.w. is the tc maintained in the sdi output? does fcp handel this tc information?
    also i just read about the hdv firewire to proress direct capture methode would this contain the tc
    would this be possible for the xdcam ex also?
    thanks in advance for feedback
    cheers
    martijn
    The box said ‘Requires Windows 95, or better.’ So I bought a Macintosh.
    Anonymous replied 18 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
