Activity Forums Apple Final Cut Pro Legacy XDCAM EX in FCP6
  • XDCAM EX in FCP6
    Posted by Geugie Hoogeveen on February 28, 2010 at 7:21 pm
    Question :
    is it possible to use XDCAM EX .movs from the JVC HM700
    in FCP6?
    And, if so, do I need additional plugins that you might know of?
    I’ve got an PowerPc G5 Mac and Final Cut Studio 2.
    Thanks in advance
    Geugie Hoogeveen replied 16 years, 6 months ago 2 Members · 3 Replies
  • Shane Ross
    March 1, 2010 at 2:24 am
    Just need FCP 6.0.6, and you should be set.
    No plugins needed..just drag and drop the Qt files into a project…
    Shane
  • Geugie Hoogeveen
    March 1, 2010 at 9:41 am
    Thanks for responding.
    The problem I have is when I import the files into FCP 6.0 and press “render”, I get the popup that the codec is not installed.
    When I use the JVC software that came with the camera, it says it requires FCP 6.0.5, which I do not have…
    Why is it so difficult to use a quicktime file specificly designed for FCP in FCP?
    Does that make any sense?
    Thanks.
  • Geugie Hoogeveen
    March 1, 2010 at 9:46 am
    Aah, you said 6.0.6! So that’s the key? In 6.0.6 the codec is installed in the software itself, nothing else is needed… Thank you!
