Activity › Forums › Apple Final Cut Pro Legacy › XDCAM EX import problem – camera assistant coppied only the folders containing the video files
  • XDCAM EX import problem – camera assistant coppied only the folders containing the video files
    Posted by Liam Morgan on October 4, 2009 at 7:47 am
    I got some footage I’m supposed to work with, but the camera assistant only copied the folders with the video files off of the sxs card on to a drive. The sony transfer can’t recognize this as xdcam footage, as the file structure of the sxs card and whatever information is contained in the XML files is gone. I tried copying the XML files off of another sxs card, so to make the folder look like a sxs card. This results in the transfer software recognizing the folder, but all of the clips say “no codec” on them and I can’t import them.
    I also tried using vegas (which can read and edit these files) to export to MXF files. But I can’t find a way to do anything with these files either- not even VLC player can read them (which usually can do everything!)
    I’m running FCP 7. ultimatly, I need to get this footage to prores. Any help out there?
    Liam
    Mark Raudonis replied 16 years, 11 months ago 4 Members · 3 Replies
  • Daniel Ludwig
    October 4, 2009 at 8:57 am
    Hi Liam,
    maybe this could help:
    https://mxf4mac.com/mxf-import
    It could open+playback the nativ mxf-file within quicktime.
  • Rafael Amador
    October 4, 2009 at 10:29 am
    Hi Liam,
    If you have the MP4 files, you can use the SONY Clip Browser to rebuild a BVAP folder.
    Then use the Transfer Tool.
    rafael
    http://www.nagavideo.com
  • Mark Raudonis
    October 4, 2009 at 5:17 pm
    [Liam Morgan] “the camera assistant only copied the folders with the video files off of the sxs card on to a drive. “
    That should read: The “recently fired” camera assistant…
    Mark
