Activity Forums Adobe Premiere Pro XDCAM EX Clips corrupted after opening in CS6
  • XDCAM EX Clips corrupted after opening in CS6
    Posted by Gerry Curtis on May 20, 2012 at 12:46 am
    Hello,
    I recently upgraded to Premiere CS6, and opened a version of a project I’d started in CS5.5.2. I’m working with XDCAM EX footage, editing natively.
    When I play my main sequence there are tearing artifacts across many of the clips, and there weren’t any in the CS 5.5.2 version. I opened the project in CS 5.5.2 and the same sequence plays fine.
    I’ve tried cleaning the media cache, trashing my preferences, repairing my disk permissions. There are no render files.
    Any suggestions?
    Gerry
    Gerry Curtis
    digitalkilnstudios.com
    savasanafilm.com
    Gerry
    http://www.digitalkilnstudios.com
    http://www.savasanafilm.com
    Gerry Curtis replied 14 years, 2 months ago 5 Members · 7 Replies
  • 7 Replies
  • John-michael Seng-wheeler
    May 20, 2012 at 4:09 am
    Have you tried creating a new project and importing the old project into the new one?
  • Justin Ferar
    May 20, 2012 at 7:53 am
    I just finished my first project in 6 and had a similar experience but with p2 media (avc intra). Some shots had artifacts that looked exactly like tape drop outs. Only a few shots had it but what is interesting is that the thumbnails in the timeline had it bad – even though the shots were fine.
    Macpro & quadro 4000
  • Gerry Curtis
    May 20, 2012 at 8:35 am
    Importing the project didn’t work, and these looked like tape drop outs as well. I also tried re-importing the folders but it still happens.
    Bummer, I was hoping for a more stable/consistent experience in Premiere 6
    Gerry
  • Nick Brown
    May 24, 2012 at 5:38 pm
    I had a similar situation with CS5.5 and CS4. As I remember, the solution was to import the sequence from CS4. I may have needed to drop and drag the CS4 Sequence into the the CS5.5 timeline or project folder.
  • Gerry Curtis
    May 24, 2012 at 10:05 pm
    Hey Nick,
    Tried that, didn’t work, unfortunately. I finished the project in CS5, hopefully this is an exception and going forward I will have a better experience.
    Cheers,
    Gerry
  • Kate Weatherall
    June 25, 2012 at 3:56 am
    Hello Gerry,
    Hey I’ve had the “from what i can see” exact same problem.
    I edit in the Native format, Import the way adobe recommends too from the sxs cards.
    I was paranoid that the camera was corrupting the files when i managed to get hold of a mac and use FCP where they played fine. As this is the ONLY relevant forum i have found and numerous calls to customer support have not and trolling through various forums enlightened me.
    would you or anyone have the slightest inclination as to where the origins of this issue stem from.
    I have been tossing up missing codecs?
    Thanking you
    Kate
  • Gerry Curtis
    June 25, 2012 at 4:59 am
    Hey Kate,
    Adobe is aware of this issue and is working on it, there’s a pretty extensive thread on it on another forum, your “trolling” skills need a little honing, I’m afraid. 🙂
    Cheers,
    Gerry
