Activity Forums Sony Cameras XDCAM EX Clip Browser and changing file names…
  • XDCAM EX Clip Browser and changing file names…
    Posted by Jason Lyons on April 28, 2011 at 6:59 pm
    Hi there,
    I have some footage from an Ex-1 that some how has duplicate file names, but the footage is certainly not duplicate footage. I am trying to organize the footage prior to running it through XDCAM transfer. My problem is I cannot rename the file names. Does anyone know of a tool that can successfully rename the file names in the Sony EX world?
    I tried renaming in finder, that was a no go as the clip simply disappeared in Clip browser. I acts like there is a master XML that clip browser looks at and only show clips within the BPAV folder that match a master list somewhere… So, I am guessing that a tool must be used to do the renaming so that all relevant items and xmls are properly updated.
    Anyone?
    thanks
    j
    Ian Cook replied 15 years ago 2 Members · 1 Reply
  • Ian Cook
    April 28, 2011 at 7:49 pm
    Hi Jason,
    You can’t change the actual file names but you can get around this by making a sub clip. Mark in/out at the beginning/end of the clip, right-click and select ‘Make New Clip…,’ and click OK when it warns you that you’re copying the whole clip. A new clip with a new name will be created. You can keep or discard the original clip.
    Hope this helps. There may be other workarounds but this is probably the quickest/easiest. If you combine folders after deleting/backing up the original master clip they should combine properly now that there are no repeating file names.
    Best,
    Ian
    Ian Cook
    Sony Broadcast and Professional Company
