Activity Forums Sony Cameras XDCam EX-1 White balance
  • XDCam EX-1 White balance
    Posted by Vasik Greif on March 19, 2009 at 10:00 am
    Hi, I have problems with white balance settings on my XDCam EX-1. My basic question is: do I have to reset white balance everytime I change ND filter? When I change filter, it dramatically changes white balance, and I was not used to this with BetaCam… Thanks.
    Vasik Greif replied 17 years, 6 months ago 5 Members · 5 Replies
  • Olof Ekbergh
    March 19, 2009 at 12:08 pm
    I have an EX3, and I have or owned or used more than a dozen other vid cams, and I have never seen a white balance shift with ND filters. Even the screw in or 4×4 (/6) type.
    Is this a brand new camera.
    Olof Ekbergh
  • Bob Mark
    March 19, 2009 at 12:13 pm
    I believe this is an issue that was fixed with the 1.11 firmware update.
    Bob
  • Jim Watt
    March 19, 2009 at 6:44 pm
    I think that’s the case. Ever since we got that firmware upgrade we haven’t run into the white balance issue between ND filters.
    jw
    Producer/DP, HD series, “Discoveries…America”, “Discoveries…Ireland”, “Discoveries…Spain”,
    “Discoveries…Argentina”
  • Stephen Schott
    March 20, 2009 at 8:04 pm
    So how do we find out if we have that firmware update? Is there something within the menu’s that I’ve missed that tells the user, or is it a “trust” issue as to purchase date?
    When you’ve got family… everything else is extra
  • Vasik Greif
    March 20, 2009 at 8:20 pm
    Thanks for replies, I think this really is firmware thing, as I have two cameras and the with new firmware seems to work ok.
    How to check firmware: Press and hold the “CANCEL” “SEL/SET” and “MENU” buttons simultaneously.
