Activity › Forums › Apple Final Cut Pro Legacy › XDCAM & DVCProHD in one timeline
  • XDCAM & DVCProHD in one timeline
    Posted by Christopher Targia on June 25, 2010 at 6:52 pm
    I have an interview with footage in two formats, DVCProHD1080p30 and XDCAM HD422 1080p30, that need to be integrated together in one timeline, what is the best way to set up this timeline? should I use compress to put these raw files into the same format? Should I convert everything to Apple ProRes? Also 80% of the footage is XDCAM and the other 20% is DVCProHD. Any help appreciated, thanks
    MacPro Octo Core Intel Xenon 2.8Ghz 6GB DDR2 Ram
    FCP 7.0
    -I highly recomend el Gato Turbo264HD-
    Rafael Amador replied 16 years, 3 months ago 3 Members · 2 Replies
  • Shane Ross
    June 25, 2010 at 11:02 pm
    [Christopher Targia] “what is the best way to set up this timeline?”
    Either convert one format to the other (convert the XDCAM to DVCPRO HD), or better yet, use a PRORES timeline for both. And either convert both to this format (if you have the time and space), or just use the ProRes timeline and render when done.
    Shane
  • Rafael Amador
    June 26, 2010 at 5:24 am
    I’m with Shane. Having both footage the same time base, the best solution is drop them in a Prores sequence.
    rafael
    http://www.nagavideo.com
