Activity Forums Sony Cameras XDCAM driver description
  • XDCAM driver description
    Posted by Jason Goldammer on November 17, 2010 at 8:10 pm
    Can someone please explain the Sony drivers in plain English? The descriptions (sometimes) found in the release notes are very similar to each other. (ie; Browser software, Proxy viewer software, Optical browsing software, XDCAM viewer, FAM for this and FAM for that.) It would be nice to know which ones I need. Then again, maybe I need them all. 🙂
    I’ve got an intermittent file/folder structure problem when reading from my PDWU1. Sometimes the structure is correct.
    (CLIP, EDIT, GENERAL, & SUB folders with files C0001.MXF, C0001M01.XML, C0002.MXF, C0002M02.XML, etc. inside the CLIP folder.)
    Other times the structure begins with GENERAL and PROAV followed by CLPR and EDTR inside the PROAV folder. Sometimes ejecting the disc and re-inserting it a few times will cause it to read correctly, but not always.
    I have read that other Win7 (64-bit) users have experienced the same problem, but I have never read that they solved it. I installed the drivers on a 64-bit Vista computer and the structure is always correct.
    I don’t think it should matter, but I’m using an XDCAM HD PDW-F355L with Sony brand PFD23A discs. If I knew how to post
    screen-caps of the structure I would.
    Does anyone have any advice on how to solve this one?
    Thank you.
    Jason
    Chris Fenton replied 14 years, 6 months ago 6 Members · 14 Replies
  • 14 Replies
  • Ian Cook
    November 17, 2010 at 8:45 pm
    Hi Jason,
    For firewire devices you need the FAM (file access mode) driver.
    For the PDW-U1 you need the U-1 USB Driver software.
    Whenever you see an XDCAM folder structure of just PRO AV and GENERAL this means that the USB driver is either not installed or is not working properly. The reason for this is that the XDCAM folder structure we’re used to seeing (Clip, Sub, Edit, General and, depending on the device used to format the disc, UserData and Component) is virtual. What actually lives on the disc is ProAV/General with the ProAV folder opening onto the ‘raw’ MXF contents of the disc. On firewire devices there is a layer of internal software that virtualizes these directories and combines all the raw video/audio information before presenting it to your computer. On the USB drive there is no such internal software so the driver on the PC/Mac has to do this. If the driver isn’t installed or is not working, you will see the raw contents of the disc.
    Make sure you are using at least 2.3.0 of the XDCAM driver software and 2.4.2 of the drive firmware. You can upgrade/verify the firmware on the U-1 using the supplied utility app (the firmware is bundled with the app; no further downloads are required). Also, we are just about to post 2.3.2 which has a number of bug fixes and stability improvements. It will be on the US software site (sony.com/servicesplus) tomorrow, Friday at the latest. Please try this version and let us know if it improves things.
    Best regards,
    Ian
    Ian Cook
    Sony Broadcast and Professional Company
  • Jason Goldammer
    November 17, 2010 at 10:41 pm
    Thank you Ian! That was the best explanation I’ve read in months.
    My next question, which I may find out on my own in a day or two, is in regards to a hard drive back up of several discs. They were backed while seeing the GEN and PROAV. I’m curious if I connect
    the hard drive via USB (after properly installing drivers) if the “Clip, Sub, Edit, General” folders magically appear. My next attempt would be to import the MXF files in Premiere anyway to
    see if they work, even though I would need to re-sync the audio with the video. If it fails I’ll have to back up the discs again, (luckily I still have them), when the PDW-U1 displays the
    correct folder structure.
    I know I have the latest drivers installed, but the firmware upgrade on the PDW-U1 I’m not sure about. I’m about to check it out now.
    Thanks again for the help.
    Jason
  • Ian Cook
    November 17, 2010 at 11:00 pm
    The existing backups you have won’t work in Premiere or Avid. The files should really be recopied if at all possible. If you can access a Mac with FCP, our XDCAM import plug in, XDCAM Transfer, has a “virtual” file access mode capability and can read XD discs when the driver is not installed (and when all Finder sees is General/Pro AV). However it is not always able to read from archived disc images (technically that’s outside the spec of the feature, which was implemented to support the U-1 before we had a proper driver for it).
    If you are able to get to a Mac and have the files read you can export new MXFs in the proper format by right clicking on the thumbnails and selecting ‘Export to File.’
    Good luck!
    Ian
  • Jason Goldammer
    November 17, 2010 at 11:41 pm
    It seems to be working great. (Knock on wood.) Evidently the firmware was the issue. I’ll admit I was confused with the various versions out there. (ie; PDWU1 ver. 230 updates firmware to (currently) 245)
    Thank you, thank you.
    Jason
  • Clint Fleckenstein
    November 19, 2010 at 2:14 pm
    That was an extremely important piece of information, thanks! 🙂 I’m going to try to sear that into my memory so I don’t panic sometime down the road. I can see someone plugging a PDW-U1 into a computer without the driver installed and freaking when our UserData folder is missing on an archive disc.
    Cf
  • Joseph Valenti
    February 25, 2011 at 5:45 pm
    In this Tread Ian states “The existing backups you have won’t work in Premiere or Avid.” Any recent improvements on this?
    We are unable to view footage shot on a PDW 700. The footage came back on a harddrive with the following top folder structure:
    General
    PROAV
    From reading the tread I believe the correct driver is either not installed or is not working properly on the camera’s end…correct? We don’t have any xdcam readers on site. We stick to linking AMA to the harddrives and use the “Write Back to XDCam” method. Is there a way to fix the folder structure if we don’t have the original disks?
    Also. Is there viewing software that works for both XDCamHD and XDcam EX footage?
    Joe
  • Ian Cook
    February 25, 2011 at 6:12 pm
    Hi Joe,
    Sorry, but no, the files need to be copied from the correct directory. There’s no way that Avid can link virtual volumes containing the raw files.
    XDCAM Browser and Clip Browser can be used to read both EX and optical XDHD. Also we’d strongly recommend the standalone MXF player, PDZ-VX10. if you’re running Windows. It plays all Sony MXFs, full res or proxy.
    Ian
  • Jason Goldammer
    February 25, 2011 at 6:17 pm
    If I remember right, you may be able to import video and audio peices separately into a timeline from the “bad” folder structure. Tedius, but it worked for me until I updated firmware on the disc reader. The correct folder/file structure has always appeared since. (I don’t think it’s the firmware on the camera that has issues.) I haven’t heard of a way to correct the structure after it’s been written. Ian didn’t sound optimistic, so I gave up hope as well.
    Not sure if HD and EX can be viewed on the same program, but I use PDZ-VX10 XDCAM Viewer Ver2.30 to preview HD files from a PDW-F355.
    Jason
  • Ian Cook
    February 25, 2011 at 6:22 pm
    In my experience importing the raw video and audio MXFs into Avid MC doesn’t work and generates a “you can’t import this file into a bin” or “MXF I/O” error..
  • Joseph Valenti
    February 25, 2011 at 7:47 pm
    Thanks Guys. I was able to import both audio and video (at the same time) by importing the XML file into Edius. The xml file had to be in the same folder as the mxf clips. If I tried importing the XML file outside of the folder it didn’t work.
    Strange?
