Activity Forums Sony Cameras XDCAM codec or Prores in FCP?
  • XDCAM codec or Prores in FCP?
    Posted by Craig Moore on May 19, 2010 at 4:11 pm
    Obviously I have a new toy (with this second post) but I was wondering if anyone had notes of using the native XDCAM codec to edit with in FCP or to transcode to Prores in stead (which I used to do with my HDV footage).
    thanks
    Craig Moore
    Spider Video
    https://spidervideo.tv
    XDCAM Ex1-R
    MacPro FCP3
    David Burch replied 16 years, 3 months ago 6 Members · 8 Replies
  • 8 Replies
  • Craig Seeman
    May 19, 2010 at 4:50 pm
    FCP 7 allows one to edit XDCAM (and HDV) native and set renders to ProRes so one doesn’t have GOP confirms when rendering effects during editing.
  • Noah Kadner
    May 19, 2010 at 5:13 pm
    Yup- that’s what I do…
    Noah
    Check out my book: RED: The Ultimate Guide to Using the Revolutionary Camera!
    Unlock the secrets of 24p, HD and Final Cut Studio with Call Box Training. Featuring the Sony EX1 Guidebook, Panasonic HVX200, Canon EOS 5D Mark II and Canon 7D.
    Watch Formosa- My indie movie shot with the SDX900 and finished with Final Cut Studio.
  • Robert Foote
    May 27, 2010 at 7:37 am
    Be sure to set your sequence settings properly, render to the ProRes format instead of the “same as sequence codec” or it will tell you it is conforming an mp4 when you try to render.
    Adapt and overcome!
  • Craig Moore
    May 28, 2010 at 12:48 am
    Thanks! It seems to do the trick.
    Spider Video
    XDCAM Ex1-R
    MacPro FCP3
  • Rafael Amador
    May 28, 2010 at 5:07 am
    But be aware that these renders are for nothing.
    When you export, are trashed.
    Unless you deliver in XDCAM, set your sequence codec to Prores.
    rafael
    http://www.nagavideo.com
  • Craig Moore
    May 28, 2010 at 10:24 am
    SO are you saying to set the entire sequence to prores not just the renders? If so then it’d be best to transcode the XDCAM files into prores first before beginning anything…if not delivering to XDCAM?
    thanks
    Craig
    Spider Video
    XDCAM Ex1-R
    MacPro FCP3
  • Rafael Amador
    May 30, 2010 at 1:53 am
    Craig,
    There is no need to transcode anything unless you intend to work with a few layers.
    If you set your sequence to Prores, is the same that when you set “render to Prores”, but in the end you have all the renders available.
    rafael
  • David Burch
    June 4, 2010 at 7:42 pm
    Good to know. I typically edit native xdcam, as I’m typically working with 3 clips at a time in multiclip editing, and transcoding 3 2+ hour clips is a waste of time and drive space. I’ve never had much of a problem with this workflow, but I have noticed that exporting finished movie files can take exceedingly long.
